Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
2wire wireless usb adapter installation for desktop
How do you tell if this usb adapter is ok, when I try to install it , the SBC DSL installation CD does not recognize the device, and the 'ADD NEW HARDWARD' feature does not appear.....
I have no luck with A T & T support!
    Sergeant:
    Champion:
  • 427 Answers
If you go to the control panel, there should be a link somewhere where you can add new hardware. Find this, connect the device, and add the hardware.
Posted on Apr 07, 2008
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
I try to re-install the software with the CD, but when it asks to plug in the adapter it says detecting and won't ever find it, and the blue light in the adapter is not lit. When I first installed this,...
try a different USB port. With some network adapters, you have to use the same USB port you always used. And if use that port for something else your OS may not recognize that adapter anymore. if you plug it into a different one, it should pick it up as a new device. If that doesn't work, then plug it in and right click on "My Computer" click on "properties" then go to "Hardware" then "device manager" if the adapter isn't recognized then you'll see a yellow question mark in "Other Devices" right click on that and try installing drivers from there. If there is no yellow question mark then you should find the adapter in the "network adapters" menu, disable and then enable it. or click on "scan for new devices"
Nov 28, 2010 | NetGear WirelessN 300 USB Adapter WNA3100
How to connect the Microsoft Wired Keyboard 500 to the Acer Aspire One Computer? I've tried using a ps/2 to USB adapter & the acer computer says it does not recognize the device.
ok this is slightly a common problem i come across this situation quite easily, don't worry that the problem is with your usb adapter, its that the keyboard or acer does not have the software needed to run it properly if the keyboard came with a cd get a external cd player and download the software to the computer, but if it did not come with a cd *note: i assumed you have windows xp if you do not please find a way to do this with a different OS* go to control panel, add hardware then follow the instuctions there that should help you install the keyboard so you can use it, allthough if your keyboard is so old it has a ps/2 port i sugest getting a new keyboard with usb plug and use/play they are more user freindly and you will never have this type of problem again.
Feb 05, 2010 | Acer Aspire One PC Notebook
My adaptor is not recognized in my USB ports I installed the router and it completes all of its connection checks. I am trying to install the adaptor on a remote computer (in the basement) and that...
Here's what you can do since this is a USB wireless adapter, first connect the USB adapter on a different USB port on the computer better if you connect it on the back USB port of the computer tower and check if the computer will recognize it and if its recognize you can already continue with the software installation , but if not you can restart first the computer and check if the adapter will be recognized if still not the next thing to do here just to know if the adapter is good or bad is to connect it on a different computer and just to check if it will be recognized once its connected to a USB port , because a device should be automatically will be recognized by a computer once you connect it so if its still not recognized by a different computer adapter is bad...
Dec 15, 2009 | Computers & Internet
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Belking wireless adapter install
when you are advised to connect the usb adapter, it will recognise it, then the usb host controller is installed to recognise the adapter,but it should continue to instal the driver and then recognise it as Belkin 54g, if not, then you need to keep the cd rom in and then force it to install the driver from your cd drive, but it may not be compatable with ME unles you have a windows 2000 driver.
When the installation is complete you should in any case have the belkin software icon on your desktop to set up the adapter, if not then the software has not installed fully.
It will also be listed in add/remove programmes if it's fully installed.
Sep 22, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Will not install
You mean the adapter is not recognized by your computer or the setip CD is the one that is not being read by your computer?
If the adapter is the one that is not being recognize by your computer try connecting it on another USB port on your pc and if still not detected by your PC try connecting that adapter on another computer's USB port just to check if it will be detected by your pc, if not retirn the device back to store.
But if you're saying that the setup CD is the one that is not being recognize by your PC try downloading the software from the manufacturers web site.
Hope it helps..........
Jun 16, 2008 | NetGear MA111 802.11b Wireless Adapter
I DONT HAVE LOCAL AREA CONNECTION in network connection
You can download the latest lan card driver from their website, usually the drivers that are on the cd are not updated.
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=552&DetailName=Feature&MenuID=7&LanID=9
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=32&DetailID=531&DetailName=Feature&MenuID=7&LanID=9
You can also install a separate lan card on your computer or you can also buy usb to lan adapter that you can insert on your usb drive, you can google USB TO LAN ADAPTER.
Mar 08, 2008 | EliteGroup P4M800-M7 Motherboard
Try uninstalling windows version of bluetooth, then re install your adapter driver from the cd, but try in a different usb port.
Jan 17, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
126 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
