Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
I have a Lawn Machines riding mower with a B&S 18.5 V Twin engine. It wont start. It has been turning over with an unusual sound and starting until now. It will click but not fire up. Tried to jump it with a car ( Is this a no no?) Didn't work. Mower is at least 10 years old. Thinking about replacing the starter but been reading about possibility of engine compression issues ? I am not a mechanic. If you answer, please keep it simple.Thanks
My brother had a similar problem. Then I found one of the three screws that hold the breather housing In the carb. Took off head and found the other one had passed the valve and busted piston and rod.I found some parts on Ebay and was going to rebuild, then a kid down the street found me a 19.5 engine for $75. After R&R a short time later it stopped on him again.This time he DIDN'T crank anymore. I found one screw hung holding valve open but no damage. Bought all new screws and dabbed good with LOCTITE and re-installed tight. Gave good time to set. Have had no more problems and my brother is a grass cutting addict:-).
Posted on May 30, 2010
    Champion:
  • 225 Answers
Take the starter off and bench test it then you will know if it the starter,take jumpers connect the ground to frame of starter,hold unit down then touch the positive where the battery cabel was connected to the starter.this should tell you if starter is good or bad,then you can decide.
Posted on May 27, 2010
Wont run and emits white smoke
Hi Jeremy:
Sounds like there is still diesel in the fuel system.
There will be a plug on the bottom of the carb.
If you unscrew it and allow it to drain, it will flush the carb.
I'd suggest changing the fuel in the tank again.
You may also need to change the spark plug.
You won't have damaged the engine.
Cheers.
Jun 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Castlegarden twincut ride on lawn mower cutting out
some engines have a low oil level sensor yes. ck. oil level
Jun 02, 2013 | Garden
Huskee Riding Mower wont start
Try rotating the engine manually to check for any binding. I would also check the amp draw on the starter.
May 21, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
I have a briggs and strattan 18 horsepower engine on my craftsman mower and it wont start, i replaced the starter and it still wont start! It wont even turn over, in fact it binds the starter, but if I...
Have the battery tested at an auto parts store to ensure there is enough power in it. Sounds like it's strong enough to turn the motor with no compression (spark plug removed) but too weak to turn the motor with compression. Also check for loose or corroded wires.
Sep 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
338 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
