Question about Dishwashers
Repair of door seal and control knob
Repair of Admiral Dishwasher DC2466w Stand alone door seal that leaks out water, also needs new control knob or at least a picture of it to see what the settings are.
  • sherylw2 Jun 02, 2010
    Thank you so much for sending me the information to get my problems resolved. God bless! Sheryl
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16010622.pdf
http://frigidaireservicetips.com/pdfs/486_5.pdf
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
OK these service and repair manuals should give you enough information to be able to sort out your issue.
www.ehow.com › ... › Dishwashers -
http://acmehowto.com/howto/appliance/dishwasher/dishwasher.php Above and below are links that will assist you in replacing the door seal http://www.acmehowto.com/howto/appliance/dishwasher/check/doorseal.php
Posted on May 27, 2010
I don't have a model number right now, but the front door on my Admiral dishwasher is leaking at the bottom. I have changed the gasket inside the door panel at the bottom but it still leaks. This is a...
it may not be the door that is leaking if this is an older admiral or whirlpool dishwasher the lever that holds the soap door closed has a little rubber seal that after time will let water in during the wash cycle it the runs down the inside of the door and out the bottom if you rmove the in side of the door you will probably see the water trail from the wax motor down. this gasket is not expensive or hard to replace.
Mar 08, 2011 | Admiral Dishwashers
Cannot afford a plumbing or to replace the
F8 would indicate a water level failure.
Check that the drain hose hasn't dropped down too low and also check that the water isn't siphoning out because the drain hose is too far into the stand pipe.
Check that the filters, especially the fine mesh one, is clean and clear.
If neither of the above, take the filters out, clean out the black grid on the right side of the sump.. Pour a kettle of boiling water into the sump getting as much as possible into the black grid. Select the hottest wash and try the machine again.
You could also look at the below points :-
Dishwasher Leaking
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Let me know, if the problem persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Kenmore 15129 Built-in Dishwasher
Leaking dishwasher
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Asko Dishwashers
My Kenmore stand alone dishwasher leaks. the water seems to come out the front at the bottom of the door. i have cleaned the seal, but it doesn't seem to help. Any ideas?
the spray arm is clug in the hools or your spray arm stuck, put the spray arm in a position you remember run the machine for few second and open the door to see if the arm move.
Jul 13, 2009 | Kenmore 17822 Free-standing Dishwasher
Leaks from handle
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Door gasket or seal
Water-inlet valve
Hoses
thanks for using FixYa
Jan 27, 2009 | Danby DDW1805W Designer Series...
Washer is overfilling
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Jan 25, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Westinghouse 906 leaks from front door
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Oct 05, 2008 | Westinghouse 24 in. MDP531 RF...
Frigidaire Dishwasher leaking but not from door
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Leaking water on floor in front of dishwasher
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Dec 27, 2007 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
