Question about Logitech Attack 3 Joystick
The stick does not return to center upon release, it is off
Center. Can this be adjusted ?
  • 12,061 Answers
Yes this can, sometimes there are springs inside that come off the mounts, it is quite an easy repair.
Posted on May 26, 2010
    Top Expert:
  • Logitech Master
  • 76,691 Answers
No adjustment, stick is self centering what has happened is one of the centering springs or the plastic clips they fit into is broken.
2009 Grand Caravan the parking brake light stays on after the parking brake is disengaged?
sounds like the parking brake arm is not returning to the fully off position. try pull the release handle and at the same time pull up on the lever. if the light goes out then its not fully returning. it could be out of adjustment or the brake cables or sticking and need to be freed up.
Mar 10, 2015 | 2009 Dodge Grand Caravan
Clutch lever sticking upon release
Could be a clutch adjustment problem, or a wobbling pressure plate.
BUT, without YOU providing a YEAR/MAKE/MODEL, the best anyone could give is just a blind guess!
Jan 17, 2014 | Motorcycles
Front brake pads release for a suzuki 800 volusia
No adjustment...if pads are not releasing correctly it's down to one of 3 things.
Caliper sticking...clean and lubricate sliders and pistons
Seal hardening...the seal distorts slightly as the piston comes out and when you release pressure it returns pulling the piston back slightly...replace seal
Blocked return vent in the master cyl not allowing the pressure to back off...usually gives an overly hard lever feel though...clean out the small holes in the base of the master cyl
Mar 04, 2013 | 2003 Suzuki VL 800 Volusia
InBaracuda got stuck in stair - on releasing it I found a black spot on wall and the suction rubber was soft and sticky.
You cleaner was probably overheating from being stuck on the stairs. To ensure that the pool cleaner does not get stuck on stairs, there are a few things that you can do. Utilize return flow by making sure that your return inlets are pointing downward and toward the center of the pool during cleaning. Confirm that you have proper hose length. Adjust the flow to your cleaner or adjust hose weight. Finally, you can install a wheel deflector if necessary.
Feb 27, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Not releasing completely
First possibility is that the brake pedal is adjusted with too little freepay, and the master cylinder can't return far enough to release fluid pressure back to the reservoir.
Second possibility a caliper may be sticking.
You can tell that by heat, since only one would stick and the other would be much cooler. (careful not to get burned. It can easily be very hot.)
Third possibility is a bad wheel bearing, which allows the rotor to wobble and press itself against the brakes. But this should vary on turns, and feel as a vibration in the brake pedal and steering wheel.
Apr 13, 2010 | 1997 Mercury Villager
Clutch pedal sticks to floor while shifting. intermitant problem already replaced master cylander and bled lines
is there adjustment under the dash at the pedal for the problem it may be a worn out return spring re check the lines for all air to have been bled out again.
Sep 24, 2009 | 1995 Honda Accord
How do I get the left hand margine to release on my Royal typewri
Generally yoy can set the left margin all the way to the left by holding down the left margin key and pushing the carriage return button
Mar 23, 2009 | Office Equipment & Supplies
Carriage return problem
If it returns with the express key the latching mech. on the rt. side is probably gummy. Take off the case, get some WD40 and spray the mechinism that latches the ret on the rt. side below the platen.
DickyO
Dec 08, 2008 | Office Equipment & Supplies
Kenwood KD 3070 turntable
There should be a set screw that you can tighten in order to adjust the height return. If you do not have anything like this, perhaps your record is raised too much. How thick is your rubber mat? Do you have any other mats sitting on top of this?
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Aug 16, 2008 | Audio Players & Recorders
Try pressing the margin release key then backspace and reset the left margin.
Jan 14, 2008 | Brother EM-530 Typewriter
Logitech Attack 3 Joystick Logo
251 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Lyle Siemens
Lyle Siemens
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
