Question about Brother IntelliFax-4100e Fax
There is a white line running down each fax
The line is just a little to the right of center vertically. We love this fax and have only had it since November. We are a mortgage company and this problem is causing problems when we fax letters or copies of statements to our lenders.
Thank you for any assistance you may give for this.
    President:
  • 3,085 Answers
Look on top of the drum unit for a blue slider to move back and forth 10 times. You may have a bad drum
Posted on May 27, 2010
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Printer leaves white vertical lines on document
I dont know what kind of copier you have but white vertical lines are virtually always caused by a dirty charge corona.There is usually a little plastic handle, blue, green or grey, that cleans the charge corona.pull it out ONCE, push it back in and try another copy.If you have an operators manual, it should have instructions for cleaning the charge corona.Good Luck, O'scope
Mar 27, 2009 | HP Office Equipment & Supplies
White vertical line on received faxes
hi,
The upper glass is under the drum unit.
- Remove Toner and Drum Unit and you will see the glass. Try to clean it.
Bye.
Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
Black lines on received faxes
look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Jul 18, 2008 | Brother IntelliFAX 4100 Laser Fax
    Mitsubishis TV Problem
    have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
    Sep 10, 2007 | Televison & Video
    Brother IntelliFax-4100e Fax Logo
    91 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
