Question about Home
Flush button won't work. 12 yr old Duravit Toilet
We have a 12 year old duravit floor mounted toilet. The toilet won't flush when the button is pushed. When you push the button, a little bit of water goes into the bowl and that's it. I have unclipped the complete central assembly ( about a 15 degree twist) and the bowl flushes. Put the assembly back again and I might get 1 maybe 2 proper flushes via the button ( ie toilet works properly) and then back to "no flush". Any suggestions please??
  • Tacheryn McCarthy Jan 13, 2013
    My Toto is at least 11 years old. I can't find the push button style flush!
    Brigadier General:
  • 3,006 Answers
The push button siphon assembly is worn out. Just replace it entirely.
Posted on May 29, 2010
Re. Duravit Happy D toilet (tank No. 0929100005)
Remove and clean the flush valve and the flush valve seat(it is the flap that opens up to allow water to flush the toilet). Once the edges of the valve and the seat are cleaned, possibly with "0000" grit bulldog steel wool, it should not leak anymore. To make sure it is not leaking, once tank has refilled completely, put some food die in the tank. If, after 10-15 minutes, the water in the toilet bowl is colored, you have a leak from the flush valve. Replacing the flush valve is very easy - just bring the old one with you to the hardware/plumbing store and ask for a replacement. Blessings and good luck!!
Sep 23, 2017 | Duravit Home
Flush for solids does not have enouvh power for a good flush
The problem probably is in your valve which regulates output of water. Normally on these types of toilets, this is and can be the common cause.
Apr 19, 2014 | Duravit 0910100005 Happy D Toilet Cistern ...
My w/c flush non stop water flow
You need to shorten the flush time of the flush valve.
Aug 23, 2011 | Duravit 111335001 Geberit In Wall Carrier...
How do I remove the toilet seat for duravit
You need an open end wrench or socket I believe 9/16 is the size
Nov 14, 2009 | Duravit Darling Wall Mounted Toilet White
My duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
Jan 31, 2009 | Duravit 001422.00.00 Vario Connector Set...
Maybe I'm an idiot but I don't know how to get the top off of my
The cistern lid is held down by the chrome assembly (which includes the two buttons that you press to make the toilet flush) sticking up in the middle of the lid. You need to unscrew that (anticlockwise) to be able to lift the lid off, to get to the inlet valve, etc.
If the water is running in very slowly, chances are high that the small screen filter under the inlet valve is partially blocked. Working inside the cistern, you need to unscrew the inlet valve assembly (noting the order in which the various parts come out!), then unscrew the cranked fitting just under that, to get the screen/filter.
Dec 27, 2008 | Duravit 0910100005 Happy D Toilet Cistern ...
Home Logo
645 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
