Question about Brother MFC-8840D All-In-One Laser Printer
Error code a-6
Help we are having problems scaning and faxing . Can rec. but can not send due to code a-6?
  • 2,337 Answers
Check this link for the operating manual, go to page # 12-2 to find instructions on how to clear errors.
Posted on Apr 07, 2008
    Genius:
  • 3,422 Answers
Try doing a hard reset unplug all the cord from the back and then plug them back after 30 min.
Goodluck,
Please don't forget to rate the solution.
  • Priya darshan Apr 07, 2008
    Please check your drivers also..
    Genius:
  • 1,913 Answers
Reset your printer settings.
check there are no any paper jam.
also check your driver and your print method.
change your toner.
SOURCE:
What is the problem and solution to error code 420 or 321
Are you able to send fax to another # ?. Error 420 & Error 321 is mainly due to transmission of signals or incompatibility issue.
Try reducing Fax speed and turn off ECM from Fax menu and check.
Regards,
Sean
May 15, 2014 | HP OfficeJet D135 All-In-One InkJet...
I am getting a remote fax error when sending and receiving faxes. Why?
is the phone line stable..meaning no distortion ... if there is some distortion like static sound.. you won't be able to fax properly.. try enable to ECM mode in your fax unit.. ECM is error correction mode.. it should reduce the send/rec error...
May 20, 2010 | Office Equipment & Supplies
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Set the receiving machine to receive at a slower transmission speed
If the session fails after sending several pages of a large document, resend the document as several smaller documents.
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
We have an HP L7780 and have problems rec. faxes - error 232
Hate to say it, but it means "Don't buy HP printers". You'll be a whole lot happier with Canon or Epson. I had no end of trouble with more than HP all-in-one. They just get flaky after awhile, and the software (particularly scanning) is terrible.
Apr 18, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
UF-585 (AU) OPT is showing on the screen...can't send or rec faxe
Open the toner door
press
function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for machine to reboot
Jan 29, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
I have a Panasonic uf-4100 that is printing,sending and receiving with a thick black line down the middle
We have a Panasonic UF-4100 and i am having problems faxing, it comes up with NO REC.PAPER 010
Jul 15, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Cannot send or receive fax
Is the fax also connected to the pc, it may be monopolising the line.
Jan 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
Brother MFC-8840D All-In-One Laser Printer Logo
589 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
