Question about GE GSS22JF Side by Side Refrigerator
GE side-by-side not saying cold
I’ve already deathward my GE side-by-side refrigerator twice and I’ve also cleaned the filter, yet after a week or so after it has been re-plugged it will stop cooling. This has only been happening within the past month. I’ve lost food b/c of this problem. I took the icemaker out to view the fan it is working as far as I can see. It seems no cold air is getting to the refrigerator side. When I notice that the refrigerator is not getting cool, I notice that freezer it is frosting up on the back wall. What can I do to fix this or is this fix able? Help!!
  • GE Master
  • 1,606 Answers
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10101 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to temp setting .
Posted on May 27, 2010
  • 166 Answers
The most likely cause for this would be a defrost heater. if you know how to use an ohm meter, you can remove the back wall of the freezer and check the defrost heater(s) for continuity. the defrost heater failing is the most commone cause for this problem, but if the heater is good then it could also be the defrost termination thermostat or the timer control board.
Our freezer is thawing sporadically and not by our choice. We have a GE side-by-side (Mod# BSS25JSRF SS) & (Ser# FH241666). We've made sure we're shutting it properly. We've lost a lot of...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | GE Refrigerators
Defrost Timer
Hi: It is your defrost heater most likely. If not the defrost timer. The heater is in the bottom of your freezer behind the metal panel. Next time you defrost it remove the panel and inspect it. It's a glass tube with a metal coil (filament) running through it. If the coil is broken replace it. If not look into a defrost timer. The parts will be shown on sears.com with a diagram. I hope this helps. Jeff
Jun 08, 2009 | GE GSH25SGPSS Side by Side Refrigerator
GE Side By Side refrigerator evaporator freezing up
is there good airflow around unit (should be away from wall about 2 or 3 inches on all sides) you say you cleaned under so about only thing left that can cause ice is low freon or defrost timer going out slowly
Jun 02, 2009 | Frigidaire FRS-26DR7D Side by Side...
Freezer is not working but the fridge part is working
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
tryt
May 28, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
GE Side by Side refrigerator/freezer Evaporator keeps freezing up
Sounds like the auto-defrost timer has gone bad. In many cases, that is the cause. Check with GE service.
Sep 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE monogram side by side no ice water dispensed not cold
To actuate the ice maker pull the arm down and it is in the on position.
The water is actually cooled in the refrigerator section. However it is not designed for a continuous flow. It takes time for the heat to be removed between each water draw.
If your refrigerator temperature is not cold enough it will affect the water temperature also. Check the refrigerator compartment temperature with a thermometer.
May 16, 2008 | GE PSS26MGS Side by Side Refrigerator
GE GSS22JF Side by Side Refrigerator Logo
278 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
