Question about Frigidaire FRT18B4A Top Freezer Refrigerator
Unit runs, freezer icy cold, fridge warm no cold air at all!!! help
    President:
  • 3,113 Answers
T probably needs a defroster timer. You can take it apart and clean the contacts with some sand paper to fix the old one. It's located just behind the light bulbunit runs, freezer icy cold, fridge warm no cold a - 2_bing.gif. You will have to lower the cover for the light to get to it. Defrost the top freezer2_bing.gif by leaving it off for a period of time or take the shelves out and blowing hot air into the rear vents until ice melts. Then reinstall timer and plug back in. Get the whole model number and go to appliancepartspro.com to get a diagram. I fixed mine in less than an hour. frt18il6dw
Posted on Jun 02, 2010
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
M y Westinghouse mastermind fridge/freezer just runs and runs , it is cold but hardly ever cuts out
Hay Paul ,
1) Are the door gaskets torn ?
2) Is the fridge empty , in order for the unit to cycle it must replace warm air with cold air .
GOOD LUCK
APPLIANCES R'EN
Dec 11, 2013 | Washing Machines
FRIDGE TO WARM MODEL ED22DWXTNOO
It's a circulation problem so either the fan in the back of the freezer(circulates freezer and blows cold into fridge) or the defrost element. If the element is faulty the rear ices up and air won't flow. If fan is faulty it's not blowing the cold air. Remove rear panel if no ice it's the fan if its full of ice it needs the defrost element(usually get termination sensor also depending on type) If you open the freezer door and hold in the doorswitch you should hear the fan running if its working.
Jul 08, 2013 | Kenmore Ice Maker Kit For Sears Whirlpool...
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
Jun 03, 2012 | Hotpoint Refrigerators
Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
May 12, 2010 | Electrolux ER7626B Bottom Freezer...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Freezer staying cold but fridge is getting hot
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
Aug 06, 2008 | Refrigerators
Frigidaire FRT18B4A Top Freezer Refrigerator Logo
462 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
