Question about Maytag Neptune FAV6800AW Top Load Washer
Its leaking and pump doesnt work right ,so how do i get into it without destroying the case
  • 526 Answers
You need the FAV6800A/FAV9800A Service Manual and Sears Parts Direct for reference.
The first part of my Clutch Fix post will discuss front panel removal. .....Rich
Posted on May 27, 2010
My Keurig not pumping keeps turning off
Keurig will give you a 20 dollar credit on a new purchase. The machine cannot be disassembled for repair without destroying the plastic case.
Dec 18, 2016 | Keurig Coffee Makers & Espresso Machines
Hard start when unit sits for a couple weeks but will start right up if You pump hand primer 1st.
You say there are no leaks, by which I assume you mean no fuel (diesel?) is leaking out? It is quite possible for a small air leak to exist on the suction side of the fuel line and cause the symptoms you speak of without leaking any visible fuel. A friend had a similar problem caused by a fuel filter with a number of tiny cracks in the casing allowing air to be drawn in but without leaking any fuel. I experienced the same thing with a van except in that case it was a rubber O ring that hadn't seated correctly.
In the absence of air leaks the fault could be a worn fuel pump.
Mar 02, 2016 | Cars & Trucks
C180 kompressor 2002 model, power steering makes a noise.Less noise if the iol level is very low. There is a slight leak and I am thinking that it **** air and causes the noise. However it is also di
The noise is the result of air bubbles in the system due to low fluid level, if allowed to continue without repairing the leak the pump will be destroyed.
Oct 09, 2012 | 2001 Mercedes-Benz C-Class
I have an issue with a 87 toyota pick up carburetor. Sometimes it doesnt want to start and sometimes it does a friend told me its that diaphram on the front of the carb with the 3 bolts but he could not...
Okay, your freind may be right, that part is called the accelerator pump, it is used for starting the truck, when you pump the gas to start it this pumps a few squirts of gas into the carb. what concerns me is that you hold the gas pedal to the floor to start it, most of the time an internal leaking carb floods the engine and holding the pedal down will let it start, a quick test would be to use a carb cleaner spray and before trying to start the truck hit the gas pedal and see if inside from the top of the carb look and see if you see a squirt of gas spray out, you will need some one to push the gas pedal or you can do it at the carb, if it squirts gas then the accelerator pump may be good and carb may be leaking and need rebuilding but if it doesnt squirt then its bad and then i want you to spray the carb cleaner into the carb and try to start the truck and if its due to the accel pump then after you spray into carb the truck should fire up and run without having to hold the pedal to the floor, if thats the case then replace accel pump if it still doesnt fire until you hold gas down then crab needs rebuilding . good day. hope this is helpful.
Apr 17, 2011 | 1987 Toyota Pickup
Liquing water from timing belt case
The water pump is behind there and probabally leaking. Need to fix before it destroys the belt.
Nov 20, 2010 | 1991 Acura Legend
Pump just stoped pumping water
Need more info to help. Does the shaft turn? Is it leaking? You cant just say my pump doesnt work without more info and expect a quality response.
Aug 20, 2009 | Flotec Plumbing
I have been using a KB3030B electric pressure washer to clean patio and have notice oil leaking from bottom of casing. Don,t know where its coming from nor what to do
The pump has a section with pistons that must have oil. The oil/piston housing is between the motor and the water portion of the pump. Some seals, somewhere are leaking. If you run it without oil it will destroy itself. You must get it fixed and I would do so before using it again.
Jun 10, 2009 | Karcher K2.26 Electric Power Washer
Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
The powered steering in my mini is not working correctly, the steering is very heavy and it would appear the power steering doesnt exist of my mini cooper s 2004 model.
check the power steering fluid if it is full then you would have to replace your power steering pump if not you might have a leak and if so get that fixed before you destroy your power steering pump.
Sep 26, 2008 | Mini Cooper S Cars & Trucks
Maytag Neptune FAV6800AW Top Load Washer Logo
51 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
