Maxtor 160GB OneTouch III Mini USB 2.0 External 160 GB Hard Drive Logo
Posted on May 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maxtor loaded with songs.How can I get my computer to recognize t
Lost manual. how can I download ?
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on May 27, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2555461
Points
31058
Connect it to any USB port on your computer.
Windows will assign a "drive-letter" (not A:, not C:, and probably not D:) to the drive.
Then, open "My Computer", and double-click on that drive-letter.
How do i get my maxtor 160g hard drive ready for use. Bought it a month ago, moved houses and lost the manual and CD. I just plugged in the power and data plug but it is not recognized by my Lenovo...
It is not recognized because it has not been "initialized". Need to go to the Maxtor support site and download the driver software that will initialize the drive. If you boot up windows with the drive plugged into a usb port, windows might just be able to search windows update for a driver or a small window may pop up and state that the drive has not been activated and would you like to open the activation wizard, click yes and follow the prompts.
tip
Song Formats for Mp3 Players Explained, Part I By Tha Mp3 Doctor I have seen...
By Tha Mp3 Doctor
I have seen quite a few threads around Fixya in which the stated problem is that the Mp3 or Digital Audio Player will not load the songs; will appear to load the songs but will not actually play them in the Mp3 player once disconnected from computer; will skip the songs on the player, or show only “0:00” for file length; songs “disappear” all of a sudden (although this particular problem can be caused for many reasons not covered in this article); your store-bought/burned/ripped CD’s will not load into your Mp3 player; or get the error message “File Format Not Supported.” All of these problems occur because the user is trying to download a song format that the player does not recognize. Every music file is in a certain format. The most common music file formats are Mp3, WMA, AAC, WAV, RA, etc. Each Mp3 player only recognizes a certain number of these formats. Every Mp3 Player is different. You will have to check your Mp3 player’s product specifications (specs) or user’s manual to find out which formats your particular Mp3 player recognizes. When you try to download or sync the wrong file format, you will get one of the errors that I mentioned above.
First things first. If you want to know what file type you have, then you must find the location of the individual music file on your computer, right click the title of the song, and select the option “Properties” from the menu. If you do not know how to do this, you will need to contact the manufacturer of your computer or go to www.microsoft.com. For all types of file except RA, RAX, and WMA, the “General” Tab under Properties will auto-populate. If your computer recognizes the file format, it will say something like “MPEG-3,” “Windows Media Audio” (Windows Media Player), “Real Audio” (Real Player or Real Network’s Audio), or “Advanced Audio Coding” (iTunes) or some other such designator. If your computer does not recognize the format, then you will just see a generic “Audio File,” and will have to download additional software. With WMA and some RAX files, there will also be a “License,” “Digital Rights Management,” or “Media Usage Rights” tab. I will explain these licensing tabs later, in the discussion on WMA files.
For every type of file other than WMA, the format error is pretty straightforward. You are trying to load a completely incompatible file format that is not recognized by the Mp3 player. To give you an example, there are currently no Philips GoGear Mp3 players that will load songs from the iTunes music service. The reason they will not transfer or play correctly is that the GoGear is that iTunes gives the users their songs in .AAC format. The GoGear cannot recognize .AAC format. To resolve this problem, you will have to convert the AAC song file into Mp3 format, or some other format that the GoGear recognizes (Note to the law-abiding: converting a copyright protected file into another format might be illegal. If you are concerned, I would just re-download the same song in Mp3 or another recognized file format – this will require a separate music service other than iTunes, in this example).
Please Read Part II for Critical Information...
My Computer does not show hard drive
I'm assuming you use Vista. First view the Maxtor drive (Start - Control Panel - Admin Tools - Computer Management - Disk Management) and see if Active or make it Active. You then can give it a drive letter.
2answers
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
I’m happy to help further over the phone at https://www.6ya.com/expert/phillip_293d34ebcf028794
Maxtor drive can not be detected from computer
You have lost the drivers for it. Go to Maxtor's web site and search for the drivers download for the model you have then install them.
1helpful
Songs won't go on mp3 player.
By Tha Mp3 Doctor
Songs being downloaded
What format are the files and Does your computer recognize your player? You may not have the right format; Sansa's MP3/MP4 players support different formats. But, Check out the "loading Content" section of the user's manual for multiple ways on how your can load the music files into your player. Link below:
Sansa e200_userguide_en.pdf
Down loading songs
RCA's website has the software/manual that you need if you lost the CD
Use Windows Media Player to transfer music and delete songs
As far as downloading songs, you can sign up for a wide number of music services - each one has a different download method, and the company website will explain how to use it. The problem with this RCA player is that it was tied to Yahoo!'s Musicmatch Jukebox svc, which was cancelled in October 2007, so you will have to find another music service. Some music services will recognize the RCA player directly, and you can use their svc to download the songs directly to your player. Other services you will have to download the songs first, and then transfer them to the RCA using Windows Media Player afterwards.
-Tha Mp3 Doctor
New maxtor sata II/300 h/d installation
throw windows in the trash bin and get Linux !!!
goto Maxtor website and download one of their drive install/diagnose/format programs (such as MaxBlast 5). Run it making sure to select appropriate options for XP.
1helpful
The problem is just with EXTERNAL.
Hdd is fine...Just change the external or buy new
Top Maxtor Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
