I need to know how to take the agitator apart. The agitator will not spin, so I need to see what is wrong with it.
  • oldguy5 May 26, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. Can you hear the motor????? Have you tried a different cycle???? Will it drain??? Spin????
  • 5,911 Answers
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. All these parts are commonly sold as part of their in-store inventory.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this is helpful to you.
Posted on May 27, 2010
How do you take the agitator apart to get to the screw on a GE mod WBSR3140DAWW washer
simply reach under the base of the whole agitator and pull upward,it may take some considerable pulling for it to release,then theres a 7/16" bolt to remove the agitator spline
May 11, 2012 | General Electric WBSR3140GWW Top Load...
Whirlpool washer agitator not working
You most likely need to replace the dogs in the agitator, two piece agitator design. It should spin one way and catch the other on the teeth of the dogs. It will spin freely either way when the dogs are wore out. This is for the top half of the agitator, bottom is fitted to transmission shaft. You pop the top cover, remove the 7/16 bolt and both halves together to change dogs of agitator. Pull halves apart to change dogs. Fairly simple.
Jul 31, 2011 | Whirlpool Washing Machines
The top half of the agitater does not work it just
There are small plastic parts called "dogs" that wear out. The agitator needs pulled apart and those dogs replaced. It is fairly simple to do.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor seems to run but won't agitate or spin.
Dont take it apart you dont know enough to do that safeky!
It could be the pressure switch and or hose. Put that to a local techo and see what he offers to charge to fix it.
Oct 20, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Kenmore Elite 23012 - 23014 mfg in 01 wont spin
Once the top cap of the agitator is removed, take a pair of pliers and pull up forcefully on the plastic cap inside. Then take a 7/16 socket wrench and remove the agitator bolt. Pull the agitator apart. Get part number 3366877 from any appliance parts store.
Apr 07, 2009 | Kenmore 23012 Top Load Washer
Agitator started making noise
pull the softener cap off and look in the hole there are plastic toothed pieces that wear out and need to be replaced. agitator dogs.
Jan 27, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Clothing stuck inside at bottom of Washer.
This keeps happening to me too. Solution :The fabric softner cap has two bevels on the side if you place something in it the fabric softner top will come off. Under the that cap there is a bolt, losen the bolt and the agitator pulls up. Hope this helps, my problem is that the agitator moves back and forth while spinning and causes the close to get stuck. I don't know what is wrong if you can help let me know.
Jul 08, 2008 | Kenmore 22422 Top Load Washer
Spin cycle...
Sounds like the spin tub mounting block is stripped to me. Remove agitator. Remove spanner nut holding spin tub to basket drive. The block is the aluminum piece joining the basket drive shaft. The aluminum block has two square indentions that sit down on two tabs formed on the basket drive shaft. The soft metal wears out on the block and the drive shaft isnt attached to the spin tub anymore. An easy way to test is remove agitator and put in spin. See if shaft spins but not tub spin.Let me know what you find
Dec 12, 2007 | Kenmore 24032\24036 Top Load Washer
Maytag PAV2300 AWW nevre agitates and only spins once.
Ive never seen a Maytag washer, but I think know the principle. So! I think the motor turns in one direction to wash & the opposite direction to spin. Now, if the transmission is very stiff in the 'wash mode', that could be why its not washing. The motor could be overheating & the thermal trip in the motor cutting off the electricity supply hence having to wait 45 mins for it to cool.
Not too sure! However I think I am on the right track. Let me know please
Oct 26, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
