Where will the orifice tube on a 1999 Ford Van E350 be located, in the suction line or on the high side, the van has a rear unit also. If you have a diagram please send. Thanks
  • vanbaker26 May 26, 2010
    It too early to make a comment about the orifice location, but I thank you for the information.
  • 6,918 Answers
It is either in the grill,or in the liquid line going to the evaporator,look for a swelled portion of the line.follow the small line from the evaporator to the condenser,it will be in there,one end of the line,or the other,needle nose pliers helps to get it out,sometimes you have to feel for the tube with the pliers,cause you can not see it.
Posted on May 26, 2010
We have a 2006 Ford Van that when driving over 45mph the air conditioning will cut out. Any help is good help
there is a cycle switch. on the suction line that you can replace, see your local auto parts store.
Aug 31, 2015 | Air Conditioning and Heat for Ford E350
How to install orfice tube on a 2003 ford e350 van
evacuate the a/c system,separate the high side line where the orfice tube is located,pull the old tube out of line. lubricate the new orfice o-ring with a/c oil,push into the line,reconnect the line be sure to replace the o-rings at the connection.pull a vacuum on the a/c system for at least 30 minutes,then recharge the system.
Jun 20, 2012 | Cars & Trucks
Ford van overheating
We had the same problem on our E350. Replaced thermostat, etc. Turned out to be leak in radiator. I would start there.
Jun 18, 2012 | Cars & Trucks
1999 windstar, rear heater was only blowing on med/high no stoppe
be prepared to renew both the blower motor and blower resistor. if it were just a bad resistor it should work on hi-speed only. make sure you have power to the motor when on hi speed. bad blower motors will kill the resistor. follow the water tubes from under the drivers side of van to the point where they enter the van, that is where unit would be located on the inside. be prepared to remove some seats and wall covers.
Dec 22, 2009 | 1998 Ford Windstar
Info. on 1986 ford diesel engine
Your fuel pump would be located in the gas tank. It is mounted on the pick-up tube/sending unit assembly.
Sep 29, 2009 | 1986 Ford F 350
1995 3500 Dodge van A/C not cooling properly
it is advisable to check the high pressure side can try to Joanna water condenser with a hose and check the suction pressure and measure the temperature in the ducts through the A / C
Aug 08, 2009 | 1995 Dodge Ram
2003 ford van e350 rear air vent is not blowing
Try this article. I have the same problem and I think it is the vacuum motor that controls the door for changing from hot/cold in the rear heater box (located inside behind the L rear wheel)
https://www.fleet.ford.com/truckbbas/non-html/Q19.PDF
Jul 08, 2009 | 2002 Ford E350
Can't find fuel filter on 2004 ford e350 van
Should be on inside of frame just behind the driver door. You will need the tool to pull off lines.
May 08, 2009 | 2007 Ford E-350 Super Duty Length XLT
Heating & Cooling Logo
327 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
