Question about Delphi MV10021 Car DVD Player
My dvd player will accept dvd's and eject them but will not play
My dvd player will accept dvd's and eject them. Sounds like it has power but will not play and the screen in black.
  • jmwhitec May 26, 2010
    It was working...turned it off...went in the store...came back out...black screen and no sound.
  • 12,061 Answers
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Dvd is stuck in player - won't play and won't eject
open cabinet of your dvd you will find out a lock open that pick up your disk during proseeing that is stucked
Mar 05, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
It takes multiple times for the DVD player to accept DVD
your ganna have to buy a dvd player lense cleaner disk you can get them from wal-mart or online for cheaper but it sounds like the lasers lense is dirty
Mar 29, 2009 | Sanyo DVW-6000 DVD Player/VCR
DVD input channel reads "no signal" when I try to play a DVD
First I would run a dvd cleaner in unit! Second you could take tv apart and look to see if signal cable is loose. the power wire seem fine as it powers up, and accepts an eject dvd.
Feb 28, 2009 | Proscan 32LB30QD 32 in. LCD TV
Philips DVP3345V powers off after 10 seconds.....
If unit has auto rewind \eject feature? Try getting it into F Forward mode befoe it powers down....
Aug 26, 2008 | Philips Magnavox DVD/VCR Dual Player
LCD TV/DVD PLAYER COMBO - DVD WON'T ACCEPT A DISC
Turns out my suspicions wre correct about the DVD player being "sluggish" from lack of use. By continuing to exercise the drive motor by hitting play and eject while simutaneously attempting to insert a disc finally paid off. Now it readily accepts the disc and everything is functioning as designed. Trust me, I'm not going to let it sit idle for anymore extended periods...................baltogas
May 28, 2008 | Akai LCT3201TD 32 in. LCD Television
DVD keeps ejecting
I have the same problem.I can only get the recorded dvd's to play on the cheap dvd players like apex and such.
Mar 08, 2008 | Mintek DTV-323 32 in. LCD TV/DVD Combo
Appears a blue screen and lost all controls
Sounds like a thermal related problem (it's getting too hot). There's not alot you can do since it's likely a design flaw that is at the circuit level.
Sep 21, 2007 | Delphi MV10021 Car DVD Player
Delphi MV10021 Car DVD Player Logo
316 people viewed this question
Top Delphi Car Audio & Video Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
gmduvall
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
