Question about Intex 2000 GPH Filter Pump and Chlorinator Combo
The low flow alarm goes off
We have cleaned and checked for debrie start the pump and the flow is fine then it slows down again and alarm goes off what are we missing?
  • 12,061 Answers
Check ALL sensors i can almost guarantee that it will be a faulty sensor.
Posted on May 26, 2010
Why do i keep getting the low pump flow alarm?
are filters clean? if so check to see if impeller on pump is plugged sometimes hair and debris get caught in it
May 15, 2014 | Intex Krystal Clear Saltwater System Pool...
Low flow rate
You probably have debris clogged in the impeller. The pump has to be opened to clean or repair the impeller.
Apr 12, 2013 | Hayward C550 Swimming Pool Filter System...
I have an LG front loader - model WD - 804 90TP and the machine is working but it gets down to 6 mins to run the spin cycle and then goes up to 14 mins and then back down again and carries on in that cycle...
You need to check the inlet valve for good flow of the water as a SLOW water pressure can increase the timing for rinse and spin.
Similarily the DRAIN pump/valve must be checked as if this is clogged then the drain flow will be LOW and the timing will extend for full drain. Remove and clean the drain pump and it can be the reason that the clothes are still wet.
Finally check on the controller for the proper timing of the cycle.
Tips on Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | LG Washing Machines
Hansgrohe Ecostat (with part 94282000 thermostat). Shower runs fine for a few minutes then boiler shuts down and shower runs goes cold. Boiler starts up again after 30 seconds and runs fine for a few...
Check the 94282000 cartridge for debris on the filters. If your boiler requires a certain flow rate to come on, then you must get enough flow through the cartridge to make that happen. Also, if your boiler is producing very hot water, the cartridge will self regulate and reduce the hot flow accordingly. try lowering the output temperature of the boiler to resolve that possibility.
If you need further assistance, you can call us direct at 800-334-0455
Sep 03, 2011 | Home
Low flow keeps alarming
the manual doesn't tell u but the obvious solution is debris trapped in the filter that water flows from the pool to the pump. The one screwed into the pool liner. Unscrew the Blue cover , the one on the inside of the pool, and u will be surprised how much junk gets trapped in there, clean it out once and week and after vacuuming the pool
Jun 04, 2011 | Intex '10 Saltwater System Pool...
I keep getting code 90 (low water flow) on my Intex Salt Water System for Above Pools. I imagine that it could be a result of my water filter not being powerful enough. Could be the problem. I want to be...
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
New pressure washer has started and ran for about 1.5 hours. After it ran out of Gas, refilled and now it runs for about 2 min then stops. Its the same gas that was used when it ran for 1.5 hours. Any...
New machine... there are a few of things to check.
First off re-check the engine oil level. The engine has an oil level sensor and will shut off the engine when it senses a low oil level.
Then with the FUEL SELECTOR "off" remove the fuel hose to the carb. Using a catch container check the fuel flow when the fuel selector is turned "on". It should be a very rapid rate.
If you do not have good feul flow check the filter / filter bowl for debris. If nothing is discovered and you still have poor fuel flow check the fuel tank outlet port.
FUEL FLOW to carb is good Symptom persists
FUEL SELECTOR OFF
Remove the fuel float bowl and check for debris. There is an orifice jet in the bottom of the carb assy that gets clogged. Also take a look at the bowl nut for debris and clean as necessary.
Again using a catch container turn on the fuel selector with the float exposed. Fuel should flow rapidly with the float down and stop as you GENTLY raise the float to level. If it is still slow there is debris in the float needle seat and it will have to be cleaned out.
Fuel selector OFF
Reassemble / install the float bowl and test.
Fuel selector ON
Test for proper operation
Thanks for using FixYa,
Kelly
May 02, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
Pool pump intex 51 pumps water but return flow is low
if you cartridge is completly clean then start by disconecting the out tube that goes to the pump housing
sometimes debris gets caught there entering your pump.
a little hair causes other things to back up
once you are satisfird that those 2 things are ready then close it all up and open the bleeder cap on top of the cartridge holder
Now let water in from the suction side
when water starts coming out of the bleeder cap then open the return side
Now turn on the puimp
let it run for 20 seconds and then close your bleeder
Should be working fine after that.
dont forget to leave the bleeder cap alone on the bottom of the canister unless you are draining the water from the canister to clean it. As soon as you are done close it back up
Jul 15, 2009 | Intex Plunger Valve & Straniner Basket set...
Low pressure flashes when i try to turn on the heater
check strainer and skimmer for excess debris that will cause low flow to heater thus not engaging pressure switch.make sure filter is clean.if all of these check out ,take continuity reading on pressure switch.if no continuity,try to adjust pressure switch if it wont adjust ,its faulty.take extreme caution when adjusting make htr will shut down when pump goes off
Jun 23, 2009 | Jandy Lx Pool & Spa Heater - Electronic...
Intex 2000 GPH Filter Pump and Chlorinator Combo Logo
175 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
