Question about E-Machines T2682 (000002965) PC Desktop
I have an emachine cpu and it comes on but my monitor is just black it wont boot and yes the monitor does work can n e 1 give me sum advice please!!!!
  • 2,404 Answers
Since you know the monitor works, I would go ahead and with the power off, unseat and reseat the memory one stick at a time in each slot one at a time. Try turning on the computer after each memory reseat. This way your testing each slot and each memory stick. Take a can of air and blow it in the slots of the memory so that way the slots are free of dust and debris.
If the memory isn't the issue, then go ahead and unseat and reseat the CPU. Like with the memory make sure there is no dust or dirt in the area by using canned air.
If reseating the CPU doesn't fix the issue then go ahead and disconnect the power to everything inside of that computer. Only make sure the connector to the motherboard is hooked up. If you finally get video when you turn back on the computer then at that point, hook up one device at a time, like the hard drive first, then the dvd drive, etc. Do this with the power off and then turn it on as you hook up each device again and as long as you get video each time then that means a device wasn't hooked up all the way properly.
If you dont get video after only hooking up the power supply to the motherboard and turning it on, then that means the motheboard is bad and would need to be replaced.
Posted on May 26, 2010
When i turn on my PC toys CPU and emachines monitor it says disk boot failure enter system disk
hi,
you have two option as follows:
1.when you start PC press F2 enter in BIOS set it to boot from HDD then restart,if this step does not help then number 2
2.reinstal the OS
Sep 26, 2012 | E-Machines eMachines Desktop PC
Worked fine last night, discovered it this morning still turned on but no signal to monitor. Rebooted and it began a consistent beeping with no signal to monitor. Unplugged several times to no avail....
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Dec 13, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
My lil bro Computer wont relay any video
You have done a lot of the basic maintenance steps. You might want to try and reseat the CPU. Sometimes they "creep out of their sockets because to the heat. Also, check to make sure the CPU fan is running if you are sure the power supply works. Without a fan, the CPU can overheat and produce your symptoms. Hope this helps.
Apr 21, 2010 | Computers & Internet
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
LCD monitor signs "no signal" on eMachines t3418
E-machines had had a long history of bad power supplies. I've seen many of these machines go bad and when they do they take out the video chip (Nvidea) with it, usually shutting down the whole machine. I've never seen one operable. You might be able to insert a video card.
Mar 23, 2009 | E-Machines eMachines Monitor E15T4
My eMachine momitor won't work with another CPU
Run a memtest to see if your ram is faulty. If it is replace and go.
Jan 20, 2009 | E-Machines eMachines Refurbished EMA...
Emachine monitor E17T4 does not respond when the front switch is depressed
Have you found a solution yet? I just posted the same problem with my E15T4.
ken
wa2kkg@gmail.com
Dec 18, 2007 | E-Machines eMachines Monitor E15T4
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
E-Machines T2682 (000002965) PC Desktop Logo
96 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
