Question about Lakewood Oil-Filled Electric Radiator Heater
LAKEWOOD OIL FILLED HEATER
Rocker switch for 600w and 900w combo is no good now, don't see a model # on the heater. Switch is a Defond DRH-2415 15a 125VAC
I replaced the switch on my heater with compatible rocker switch from ebay:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l2736&_nkw=Double+Red+Light+Button+ON%2FOFF+Position+Rocker+Switch
It works very well.
Posted on Feb 04, 2012
  • Richard Robison Apr 12, 2014
    Unfortunately, this switch failed after two years. The heater still works well, so I may replace the switch yet again.
  • 4 Answers
If it looks like this you can find one here
Defond DRH-2415 15A 125VAC Lighted Dual Heater Switch
Posted on Jan 14, 2009
  • 3 Answers
Get two Garder Bender GSW-42 rocker switches, cut and file one side of the front plate of each switch so that they mate, widen the hole slightly so they fit and you are done.
Posted on Dec 11, 2011
  • 3 Answers
Try this link http://www.nelsonappliance.com/Space+Heater+Parts.html
Posted on Dec 04, 2008
The rolling feet are missing. Any idea how to find replacements
I have a Lakewood 7096 heater. We purchased it used and got 8 to 10 years of service out of it. It was never heavily used while in our possession, just to heat the bathroom for showers.
The 900W switch quit working after used it and showered Sunday. The 600W switch still works fine, but the unit doesn't produce much heat at any speed.
After looking at various posts on fixya today, I decided to pull the pair of switches out. The 900W switch is burnt. The wire attaching to the 900W switch is burnt and bare!!! I don't know what happened. I would be scared to use it again, even if I replaced the switches and the bare wire. I don't know if it's even safe to use the 600W setting.
Anyway, I purchased a sunbeam radiator heater this morning. The ol Lakewood has the wheels you are missing. If were to come to an agreement on price, I would be happy to ship them to you. They are in good shape, just a little squeeky, which a little oil would fix.
Jan 17, 2011 | Lakewood Oil-Filled Electric Radiator...
How do I replace a delonghi typ 3107 dual rocker
Remove one phillips head screw that is located approximately 4 inches above the switch you are about to replace. The complete face of the heater can now be removed, then compress the four tabs on the back side of the switch to remove the switch through the cover.
Dec 02, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
The 900w on/off switch does not work. any
You can go to the radio shack and purchase a universal switch to replace it.As long as the replacement switch will hold 900 watts or more(125volts)it will work.Take the switch with you.Replacement parts are almost impossible to find.Hopefully,this will help you.As the heaters go out,switch or thermostat,or element,I but a new one,I have been for a long time.I end up with extra parts to fix one or two,so I end up using the heaters longer than expected.Don`t buy the digital L E D versions,they won`t work right,and go out quickley. If I can help,let me know.I hope this is helpful.
Sep 29, 2009 | Lakewood Oil-Filled Electric Radiator...
ROCKER SWITCH DIAGRAM
On the top of the switch (inside the heater) there is a common connection.....even though it looks as if it is connected (electrically), it isn't electrically affected by the switch; it's just used as a post. It's just the place where the striped wire connects to the "common" point for the heater coils (they are in a parallel). Also, while you're in there you might want to put some electrical grease on the exposed conductors.....mine had quite a bit of corrosion (which was the reason for the failure). I had to replace 3 of the female connectors.
Aug 27, 2008 | Lakewood Heating & Cooling
Switch
Mar 24, 2008 | Lakewood Oil-Filled Electric Radiator...
Lakewood 7096
i went all over town looking for a switch. finally found two lighted switches at grainger carling technology part no. 1A824. ground down the outsides glued both together jumped across top and bottom terminal with copper wire and it seems to work fine now.only time will tell. i hate our throw away society which the junk imported in from china seems to foster.
Jan 07, 2008 | Lakewood Oil-Filled Electric Radiator...
Rocker switch for 600 watts broken----
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Dec 01, 2007 | Lakewood Oil-Filled Electric Radiator...
Lakewood Oil-Filled Electric Radiator Heater Logo
1,555 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
