Question about Polaroid TDA-03211C 32 in. LCD HDTV
For Polaroid TDA-03211C - I put a DVD in the built-in DVD player and it will not play. Not only that, but it will not eject my DVD. I just want to find a way to get the DVD out. Please help!
  • Polaroid Master
  • 12,061 Answers
Ok,if you look carefully in the front of the tray, you should see a little "hole" using a straightened paper clip or the like, insert the wire into the hole, and push in, keep pushing until you her/feel a "Click" now, keep pushing past this point gently, and the tray should "Pop" open, Violla.
www.hdtvreview.com/pdf/polaroid-tda-03211c-manual.pdf
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Polaroid, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on May 26, 2010
  • 2 more comments
  • electronic & computer repair&  servicre
    Well good luck
    Cannot unlock the question
    Cannot get this post unlocked?
2 Suggested Answers
  • 1779 Answers
SOURCE: have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Posted on Mar 04, 2009
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
How to work my built in dvd player in my polaroid tv
The owner manual should have that--you can try to Google the model number with the wordv"manual" to try to locate the info.
May 16, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Cant get movie to come on.it says to hit play button.cant find any such button.picture comes on but that is it
The Polaroid TDA-03211C has the Play/Pause and Stop/Eject buttons on the TV on the side of the TV near the DVD slot. They are separate from the other control buttons. (They are closer to the back of the TV relative to the DVD slot with the stop button the lower of the two. The play button is just below the media card slot behind the DVD slot.) The original remote also a Play button (center two rows above the channel and volume toggle buttons).
The manual for the TDA-03211C is available as a PDF from HDTV solutions: http://www.hdtvsolutions.com/pdf/tda03211c_ug_en.pdf . See page 12 (page 14 of the pdf) for the controls on the TV and page 14 (page 16 of the pdf) for pictures of the remote.
I hope this helps.
Sep 04, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
My dvd is stuck in the tv
while it is trying to eject tap on back of dvd player
Nov 20, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
Hi. Hope you can help with a DVD problem we have with our Polaroid TDA-03211C television: After I insert a DVD, I hear two clicks and then the message "No Disk" appears on the screen. The DVD player is not...
We had the same problem. Call Polaroid and they will send you a replacement dvd player. It was a malfunction on their part. It seems the DVD player gets too hot and then it doesn't work anymore.
Nov 27, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I have a 32" HD widescreen LCD TV/DVD combo. TDA03211c. When I put a dvd in to play it makes a noise and puts some digital garbage on the screen. Will not play dvds.
Sounds like the DVD player is defective. Just food for thought.. Try not invest in any make with a built in DVD player, they just don't last.
Oct 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
A dvd is stuck in the dvd player of my polaroid combo tv/dvd player
if you will look under the drive where you put the dvd in there is a little pin hole push a small paperclip in there and the dvd will pop out
Jul 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
I''ts the same problem dvd says no disk
I have a working DVD unit from my 03211c and I part with it for $30.00 you pay the postage. This DVD 3003391292478080_1.jpg Polaroid TDA-03211C DVD MECH 926-V00-DSL900Dhas no markings but was built into my 03211c in June of 07.
cell: 1-717-781-7907
I also have anything else you you need for his TV. I'm parting it out because the LCD screen is cracked.
Jun 20, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
Feb 28, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Polaroid TDA-03211C 32 in. LCD HDTV Logo
318 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
