Question about Mitsubishi M-VR700
Why wont my turntable work? it works when hooked up to other receivers. i get nothing
  • 26 Answers
Most new receivers don't have an input for PHONO. If yours doesn't you will need a phono preamp between your turntable and your receiver. Cost about $30.
Posted on Jul 06, 2010
3 Suggested Answers
simplemitch
  • 752 Answers
SOURCE: No Sound from Turntable
It definitely has to go through a preamp (a PHONO preamp that is...) something like this: http://www.phonopreamps.com/tc400pp.html
Posted on Sep 14, 2007
  • 4234 Answers
SOURCE: i purchused a turntable and
Turntables have extremely low outputs and require a phono input on the receiver. If yours does not have one, you need to purchase a phono pre-amp. This will boost the signal to the level required for any aux or tape input on a receiver.
Dan
Posted on Apr 08, 2008
Technics SL-D33 Channel drop.
There's nothing wrong with the turntable then. It's your receiver that's the problem. In order to hear a magnetic cartridge it has to go via a pre-amp. It's this pre-amp that has failed in your receiver. It's only used by a turntable so wouldn't affect anything else. You should be able to trace this pre-amp by following the turntable socket wires. It will probably be a small IC that has failed. If you look up the number you should find it.
Nov 30, 2013 | Technics Audio Players & Recorders
I hooked up my T.52x turntable to my pioneer vsx-d711 receiver through the RCA input...nothing fancy. I have to turn my receiver volume all the way up in order to hear the records. All the digital media...
The signal produced by a phono cartridge is much smaller than a standard Line Level component produces. That is why the clas of equipment called PREamplifiers existed. Besides PREamplifying it to a level the rest of the circuitry can use it also modifies the frequency curve according to the RIAA standard to produce a sonically flat output. Without either process applied you will have weak, tinny sound from a turntable.
The Pioneer VSX-D711, like most modern AV receivers, is not equipped with a Phono Preamp. If the connector doesn't SAY Phono is won't do Phono.
Dec 28, 2009 | Stanton T.50 Turntable
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
Can't seem to get any music from the turntable
Do you have the ground wire from the Turntable hooked up to the receivers ground terminal? it's a screw down silver nut and should be next to the Phono input. You are just lacking a ground from the turntable to the receiver. If you don't see a wire from the turntable, look around the chasis of the unit and you will fins it. Hope this helps
Jun 21, 2009 | Yamaha HTR-5740 Receiver
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Sound problems on my turntables
yes ground the turn tables usally have ground wire u tie on to bolt on back
Oct 07, 2008 | Yamaha RX-V995 Receiver
How to hook up my turntable to my RCA home entertainment system
http://www.htfr.com/more-info/?catno=MR155277.
please buy the item above -----connect your turntable to input and take the output and connect it in line in in receiver.
Aug 11, 2008 | Audio Players & Recorders
I purchused a turntable and tried hooking it up to my A/V receiver and nothing is working. any advice on how i can get this to work?
Dan
Apr 08, 2008 | Audio Players & Recorders
Hookup
what turntable specifically....
jeff
Feb 22, 2008 | Denon AVR588 Receiver
Sep 14, 2007 | Nakamichi AV-7 Receiver
Mitsubishi M-VR700 Logo
123 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Todd Arndt
Todd Arndt
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
