Question about Brother MFC 210C All-In-One InkJet Printer
Cant use my printer (brother mfc 665 cw printer
It says unable to print 50
    Problem Solver:
  • 11 Answers
I had this same problem and it is an easy fix. It is similar on all brother printers but mine was a 5860CN.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lift the encoding strip upwards slightly and move slightly towards the back of the printer. This will locate it back into the correct position in the print head when you release. You can feel this with your fingers. Power back on and the problems will be gone!
Remember and be gentle so as not to damage the encoder strip!
Posted on Dec 23, 2010
  • 120 Answers
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Hope that helps.
Posted on May 26, 2010
How do I set my Brother NFC 665-CW to print multiple pages?
do u mean the whole multi-page doc or multiple copies of the same page?
the former would be what u tell it to print (whole document vs current page). The latter would be in the printer properties config page.
Sep 21, 2014 | Brother MFC-665CW All-In-One InkJet...
My brother mfc 665-cw is saying offline no matter what I do to try to print wirelessly
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Apr 25, 2011 | Brother MFC-665CW All-In-One InkJet...
My Brother Printer MFC 665-CW just came up with a message Unable to Print 4F
Hi there
Worth a go/
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
INSTALLATION
this is a complex machine, without its documentation it would be very hard to figure out, so the install and setup guide is available from brother, its available here
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_MFC_665CW_EN_382.PDF
and here is the units operator manual, this will take you to it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_440CN_665CW_845CW_EN_287.PDF
following the install guide is pretty straight forward and should result in a satisfactory setup.
Oct 17, 2007 | Brother MFC-5460CN All-In-One InkJet...
Printer message: Unable to Print
5A means that the purge cam stopps abnormally when it is in use. This could be of a broken cam shaft. You have to replace the whole purge unit. This is a service job to do!
Aug 27, 2007 | Brother MFC 420CN All-In-One InkJet...
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
157 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
