Question about GE XL1800 1100 Watts Microwave Oven
I have a GE microwave model JVM1851SH06 that is completly dead. I replaced the Fuse and power came back, but 30 sec in it was dead again. What should do next.
  • GE Master
  • 9,047 Answers
You need to first verify that your outlet is correct at 105 to 125 volts AC.
If so, then you may have a failing high voltage transformer (rare) or possibly a failing magnetron, etc.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
http://www.gallawa.com/microtech/xformer.html
Posted on May 28, 2010
"ge spacemaker microwave oven model jvm1530"
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt http://www.microtechfactoryservice.com/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 17, 2013 | Microwave Ovens
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE model JVm1650bh05 Microwave. I put in
Check the fuse in the bottom of the oven ... near where the power cord enters.
Oct 19, 2009 | GE JVM1630 Microwave Oven
Microwave shuts off after running for five minutes
I'd be careful because you do not know what caused it to spark. How old is the microwave? Do you need a new one?
Jun 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1630BJ Microwave went completely dead with no power
Sounds like the bulb shorted, which is very common, and the first time it blew the fuse.
It sounds like when you put the new fuse in and tried it again, the bulb was still shorted, and this time it damaged the board.
We see (and repair) thisa lot. The problem is on the control panel, whichwe regularly repair nationwide by mail for $39.95 postpaid in about aweek.
Atour Web site, we have a videoavailable showing how to remove a typicalover the range control panel assembly in under 5 minutes.
This light failure oftenoccurs when a bulb goes out and the filamentshorts, or when the bulbs are removed or installed without firstunplugging the oven from the power line. Either can cause such afailure on the controller.
This can often alsoaffect the exhaust fan operation, too. The lights and fan can beinoperable or stuck on too.
Details of our serviceand critical safety information and disassembly information is at oursite, and our link is at ourlisting hereon FixYa.
Feel free to contact me directly (and please remind me of yourfull model number) for more information & help.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
You may have a blown internal fuse. While I would recommend that you take the unit to a qualified repair center, you can do a little troubleshooting on your own. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement fuse at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
If the unit does not come back on, then there is a possibility that the unit's power supply has failed.
Please let me know if I can be of further assistance to you.
- Jim
Jul 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Complete Shut-Down
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 23, 2007 | GE Monogram ZE2160SF Convection /...
GE XL1800 1100 Watts Microwave Oven Logo
397 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
