Question about Haier 539490003 Air Conditioner
The air conditioner does not cool and it clicks low then goes back to high
  • 901 Answers
Check your program setting first. Contact service center for assistance as it is difficult to find further. May be micro controller problem.
Posted on May 27, 2010
Haier a/c model esa408k-l mode is set on cool, speed set on high temp is 81 held temp button down, goes to 61 with in seconds goes back to 81.
Free Haier Air Conditioner User Manuals ' ManualsOnline ...
homeappliance.manualsonline.com > ... > Household Appliance Haier
Products 1 - 50 of 548 - Haier Split Type Room Air Conditioner Operation Manual. Pages: 0 Saves: 0 ... Haier Room Air Conditioner Installation Manual. Pages: 0
Aug 26, 2015 | Haier Heating & Cooling
When i put the tstat on high fan it goes back and forth from high to low
Need to check the cap on the unit it is a silver can may be shorted
May 20, 2014 | Dometic Rooftop RV Air Conditioner
My Sanyo ac outdoor is overheating and then goes off what could be the problem
If the unit is overheating, I'm assuming the compressor is getting hot. It could be drawing high amps, do to a bad capacitor, bad motor, a dirty condenser coil. It also could be low on refrigerant and not getting the proper cooling back to cool the compressor.
Mar 24, 2014 | Heating & Cooling
Air conditioner issues
it sounds like the climate control is messing up and needs to be replaced.
Jul 02, 2012 | 1996 Lincoln Town Car
I have a rooftop ac unit on my popup that was replaced two years ago. The unit works fine but I would like the fan to shut off when the compressor isn't running. Is there a switch for putting the fan...
Please describe your controls. Does it not have low fan, high fan, low cool, high cool on the dial at ceiling? If yes, low cool or high cool setting should shut it down when temperature is reached via thermostat dial.
Aug 29, 2011 | Dometic Rooftop RV Air Conditioner
When in cooling compresor will not re start unless you are at thermorstat,move control to heat and back to cooling
moving the stat from heat to cool etc resents a fault in the control board of the inside unit or outside. Usually a high or low pressure problem
Aug 17, 2010 | Weather King 10AJA6001AH Air Conditioner
Air not very cold. Any advice
Make sure the condenser fan and evaporator fan are running. Check your filters. Make sure the coils are not clogged with dirt or dust. Make sure the compressor is running. Get the refrigerant charge checked.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
What does the mode button do?
The mode button can be changing it from low speed to high or if it is a heat-pump, from heat to cool. Normally, its the mode you want to run it in, if its only an a/c unit, it would have to be low cool, med cool, or high cool. Its unfortunate you have misplaced the manual as it can come in handy for trouble-shooting in the future. I would go back where you bought it and say it didn't come with one.
Sincerely,
Shastalaker7
Jun 09, 2010 | Kenmore 75085 Air Conditioner
I have a Maytag portable air conditioner (about 5
when the compressor shuts off most of the freon goes to low side(cold) when it starts..it has a lot of freon to move and it works hard and you hear it loud after it has moved most of the freon over to the high side,the sound is less so not to worry it's normal if it clicks when it starts then you worry
9
Aug 20, 2009 | Heating & Cooling
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Haier 539490003 Air Conditioner Logo
41 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
