Question about Pioneer AVH-5700DVD Car DVD Player
How do you get the aux to work on the avh-p5700dvd?
SOURCE: Which navigation unit do i need for the AVH-P5700DVD? AVIC 80DVD,AVIC 90DVD,AVIC 9DVD
try the avic 880dvd or the avic 88dvd
Posted on Mar 27, 2008
ward_knutson
  • 64 Answers
SOURCE: avh-p5700dvd touch screen
Go to: http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF This manual will give you everything you need for your Pioneer unit.
Posted on Nov 25, 2008
tech48
  • 624 Answers
SOURCE: avh p5700dvd ..Noisy distorted sound from RCA output
This model of Pioneer has a common problem with a couple of fuses that are inside the unit mounted on the main circuit board that will blow. These are surface mounted fuses, and must be replaced with the same type of fuse. They are very small and white colored and require some good soldering skills and the proper soldering equipment do this job properly.
I work at an authorized Pioneer service center and have seen this problem many times. These units are very difficult to open up and work on. It is very easy to damage the ribbon cable that connects the flip out monitor to the main circuit board if not done perfectly.
What you can do as a work around for a short time, until you can get it in for repair, is this shortcut. It will restore your audio, but should not be considered a permanent fix.
At the amplifier (since it is easier to get at than the RCA cords coming out of the back of the Pioneer) you need to connect a jumper wire from the RCA ground on the jack to the power ground on the amplifier. The outer metal part of the RCA jack is the ground, the metal pin in the middle is the positive.
Remember, this is only a short term temporary work around and is not a permanent repair. You just need to supply the RCA output ground with a good ground.
The repair of replacing the surface mounted fuses can cost anywhere from $100 to $160, depending on the service center rates. Just don't wait too long, or play the amplifier too loud in the meantime.
Posted on Feb 05, 2009
pumpkinman
  • 1147 Answers
SOURCE: i have a avh p5700dvd and when i put a cd in it reads error 02
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/212667155AVHP5700DVDOperationManual.pdf
Posted on Nov 07, 2009
pctech1
  • 1940 Answers
SOURCE: help i need a wiring diagram for a pioneer
ftp://extra.abt.com/PDF_Files/avhp5700dvd_installation.pdf
This is the installation manual for the AVH-P5700DVD, including a wiring diagram for the wiring harness.
http://www.pac-audio.com/PACProductData/TR7/1_Instructions/tr-7_instructions_010505.pdf
This is the wiring diagram for the PAC TR-7 UNIVERSAL TRIGGER OUTPUT MODULE VIDEO BYPASS.
Posted on Jan 12, 2010
Can i hook an ipod up through an aux cable that plugs in to the ipod . its the red and white aux cable and it plugs into the earphone place on an ipod
If you are talking about the cable I think you are, all you do is plug the red and white rca into the input of your choice on the back of your radio and the other end into your choice of audio output (anything with that size headphone port).
Sep 19, 2010 | Pioneer AVH-P5700DVD Car DVD Player
AVH-P5700DVD Car DVD Player: how to re-calibrate the touch screen for a Pioneer...
In order to calibrate the AHV-P5700DVD you need to press and hold the Boost and the + button and then press the reset button with a pen. continue to hold the Boost and + until the screen opens back up and you can see the calibration screen. use the arrow nob on the right to select the menu item, and the A button to select your item.
May 17, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Help i need a wiring diagram for a pioneer avh-p5700dvd to connect to a wiring harness and a tr-7 output module
Jan 12, 2010 | Pioneer AVH-P5700DVD Car DVD Player
I have a avh p5700dvd and when i put a cd in it reads error 02
Nov 06, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Please help me enable the aux mode on the above unit, i have connected ipod to aux input, no sound as not enabled, many thanks, Pioneer AVH-P5700 DVD car stereo
Have you tried going into the menu and searching for this function?Also some car stereo's have a sub menu when the radio is turned off or in stanby mode it usually can be reached by pushing your menu button and holding for a few seconds also again the power has to be in standby mode. if this works look through menu for your problem.
Nov 04, 2009 | Pioneer AVH-P5700DVD Car DVD Player
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-5700DVD Car DVD Player Logo
53 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
