Question about Vizio VP322 32 in. Plasma TV
For the past 4 days or so when I turn it on it will cycle on/off numerous times before powering up and staying on. Today, however (5/26/10), it would not power up at all - nothing, no light in front, no powering up sound, nothing.
  • Vizio Master
  • 8,457 Answers
Ur tv the power supply board before it have those parts call capacitors it have gas leakage,that why u turn on/off numerous times it powering up.The power supply board,the board the a/c power cord go into it.that ur power supply board.Now all those gas leakage capacitors are bulges up on it top or puff on it top are total dead now.U know basic electronic's and soldering?Searches all around the power supply board and it supporting boards.Replaced all those defective dead capacitors that bulges up on it top or puff on it.Ur tv power well return and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on May 26, 2010
    Sergeant:
    Champion:
  • 431 Answers
Plasmas are a little diff in pwr supply than lcd. you can replace caps that look bad but an esr meter would be helpful alot of 470mic look good but ck bad. they are trying to charge and cannot filter the ripple for good dc.there is no gas in a cap.
Posted on Jun 01, 2010
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
The past couple day the set would turn on and off every 2 seconds. It did that for several days now it will not turn on at all. thanks..
when tv cycles on and off there is a short circuit in y or x board onplug y board try to turn on tv if you power light turns on and stays on you have issolated the problem if it dosent then do the same thing for x
Feb 23, 2011 | Vizio VP322 32 in. Plasma TV
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
I purchased my Vizio VP322 HDTV10A just about 1.5 years ago for almost $600 at WalMart. For the past 4 days or so when I turn it on it will cycle on/off numerous times before powering up and staying on....
its bad capacitors on the power board
if you can solder, you can fix it.
look for caps that are bulged up, theyre supposed to be flat on the top. google bulged caps and youll see pictures
replace with same value parts to solve, all are solder in
May 21, 2010 | Vizio VP322 32 in. Plasma TV
My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
Apr 24, 2010 | Kenmore Dishwashers
Sometimes when i try to turn on my compAQ PRESARIO F700 i have to hit the power button numerous times before it will power up and one it went into a reboot cycle where it would never make it past the POST....
the button that you're pushing is then pushing another button on a circuit board. Sounds like the external button that you're pushing isn't making good contact with the button on the circuit board. It may be turning back off while booting up because you've had to push the button so hard to get it to come on that it is getting stuck and holding down the circuit board button - causing it to shut off right away. I'm not guaranteeing that this is the problem, but I've seen it happen before. Some of the older Compaq's had this issue. If you have a mail-button (looks like an envelope) along the top strip by the power button, then try pushing that to turn on your laptop.
Mar 13, 2010 | Compaq Presario 700 470024-192 Notebook
For the past week the set cycles on-off-on.........numerous times,as many as thirty when first turning on. Now it does nothing.
sounds like you have a bad cap in your power board the power board is the one where the AC cord plugs into these can like devices will be puffed up on the tops from venting the values are on the side replace them and your good to go
Nov 19, 2009 | Vizio VP322 32 in. Plasma TV
One year to the date almost now out of warrenty it wont turn on
Mine did the same thing (VP322), I would go to turn it back on after it having been off for a while, and it would turn on, then off, then on... Over time it would cycle on and off even longer... Eventually it stopped working, would not turn on and made a clicking sound.
Mine was past it's warrently, so I opened it up and inspected the switchmode power supply board (where AC connects, and two voltage ribbon cables going to screen circuit and main circuit). On the side going to the main circuit board I noticed that five electrolytic capacitors were bulging at the top (a clear sign of overheating) and when this happens, their values (in farads) tends to drop, which can cause voltage instibilities.
The capacitor values were:
2 x 25V 1000 uF
2 x 10V 3300 uF
1 x 10V 1000 uF
I replaced them with spares and reassembled the unit, and it now works.
Hope that helps!
Jul 02, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
Anti-theft has engaged
sounds like the transmitter in the key head is defective or it lost programming, try these programing steps, if that doesn't do it u need another key made.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Apr 19, 2009 | Mercury Mariner Cars & Trucks
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Vizio VP322 32 in. Plasma TV Logo
654 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
