Question about Amcor AL10000E Air Conditioner
I am looking for a amcor spiral water pipe with connector please help
Hello, i have a AMCOR KF 9000 BTU. And was wondering where do i put the water? and why do i need water in the unit?
Unless, AMCOR has recently made a dramatic change to your model, you don't add water to the unit. Your model acts as an air conditioner and a dehumidifier, all at the same time. It evaporates the water/humidity in the room's air and exhaust it out the vent hose. There is a drain pan, that collects any un-evaporated water, but that only needs to be drained if it's full. Which rarely occurs, unless the humidity is extremely high for a long periods of time..
Hope this helped you. Please let me know. Thanks.
Jun 10, 2011 | Amcor Heating & Cooling
Where can I get a stopper to stop the water coming from the continious exit pipe and divert it into the water tank on my Amcor SD10 dehumidifier
Sorry it's taken so long for someone to respond to your question. The reason may be, that it's not very clear to us, what exactly you're trying to do. I think it's the part about "the water coming from the continuous exit pipe" and why you would want to run it into the dehumidifier tank?
So, if you could explain the specifics a little better, we may can help you.
Thanks
Apr 05, 2011 | Amcor Dehumidifiers
Thankyou Guru. I couldn't find a vent hose on the back. Ive unscrewed the bottom panel and there is a coil which looks like a heater, and a black fan type thing, but no vent hose. When I unscrewed the...
Hi, Your very welcome but there should be a round 4 inch metal vent hole with either a metal pipe or a spiral tube going into the wall to the outside. Are you looking on the front or the back? if your looking on the back that coil should be the heater and the black fan is the blower which is what moves the air across the clothes. when you turn the dryer on you should either feel the air blowing into the room through the hole if there is no vent tube on it or see the vent tube on the bottom either on the back or side.
Jan 12, 2011 | Hotpoint Dryers
How much space should i leave between loops on roof tape?
1st You must know that you can attach the heat tape by spiral wrapping, or by straight run (in- line with the pipe); held temporarily with a few pieces of tape. Of course you will need to apply an insulating wrap (in either case).
The straight run gives the least heat per foot but covers more pipe. The tighter (closer) the spiral wrap of the heat tape loops, the more heat per foot but the shorter the coverage. If the pipe is 1/2" or 3/4" DIAM. then a straight run is sufficient. If 1" to 1 1/4" then a very wide spiral. If 1 1/2 to 2" then a closer loop spiral. In no case should the loops touch each other nor be closer than 3/4" to each other. And avoid having the heat tape cross itself at valves, elbows, etc. PLease note that this is all based on winter temps of 0 degree F. or above and using normal 1" THICK WRAP INSULATION. If you have temps down to -30 or so, then give minimum 2" thick insulation.
Good Luck Macgivor.
Nov 27, 2010 | Easy Heat Water Pipe Heating Cable
Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner leaks water in side the room. after the drain hose was change and clamped.
I had the same problem. The insulation on the coper line was loose and the pipe was exposed. The water was condensation , not water from the drain.
Aug 25, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
My vent is too short on my amcor model ALTL 12000E portable ac
Try to extend the pipe using a pvc pipe or, some sort of pipe.use alluminum tape that you can get at your local hardwhare store to seal the crack in the pipe that you use to extend..
May 27, 2010 | Amcor ALTL-12000E Portable Air Conditioner
Parts for Amcor Portable Air Conditioner
Your parts can be found at amazon, click here and take a look: Finally charging for our multi device world. I hope this was helpful. Cheers
Apr 30, 2010 | Amcor AF9000E Portable Air Conditioner
Amcor AL10000E Air Conditioner Logo
66 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
