Question about Toro Lawn Mower With Toro Power Tools
How to install a drive belt on a Toro LX426 lawn tractor
  • 133 Answers
SOURCE: how do I replace the belt on my toro model 20334
You will have to disconnect the deck from the tractor. There might be some rods hanging down by the pulley on the motor. You have to loosen those not remove. Then install the new belt with the inside of belt (V) into the pulleys. The outside of belt (flat side) goes up against any idlers (oversized pulleys). Once you get the belt routed properly the belt will be snug in the pulleys. If you have excess play you have to use trial and error to get the belt routed the right way around the idlers.
Once belt is on reattach the deck and tighten the rods by the motor that keeps the belt from comming off. They need to be close but not touching the engine pulley.
Good luck and let me know if this helps.
roundo4
Posted on Sep 03, 2009
panilling9
  • 284 Answers
SOURCE: what is thje gap between the flywheel and the
.012 if its a briggs motor
you can remove the rust with sand paper to have a more accurate setting
always set the gap using the magnet side of the flywheel
Posted on Jun 08, 2009
  • 1129 Answers
SOURCE: Toro lawn and garden tractor will not start all of
Remove the two wires going to the switch and use a jumper wire to bybass the safety switch if it starts replace the switch, make sure power is getting to the relay, relays have two power wires one that activates the relay coming from the physically activated safety switch the other is a power wire that is activated by the ignition switch, you must have power to the relay with ignition key on.
Posted on Jul 15, 2009
Dolfoff
  • 148 Answers
SOURCE: hydralic drive system schematics
Z350 is not the proper model number, but if you do have the FULL and proper model number you can find toro IPLs here.
Hope this helps!
Posted on Sep 28, 2009
  • 203 Answers
SOURCE: I have a toro lawn mower. Model no. 20352. The
Go to this URL:
https://icontent.toro.com/smartmanuals/22Recycler/Proc10806.htm
On the left side of the page there are a few items for maintaining your mower. One shows how to change the drive belt for a front drive and one shows for the rear drive. Click on the one you have and it will show you how to accomplish this task. Be sure to either tighten the belt so it does not fall off again, or if it is bad, replace the belt. Please follow all safety instructions.
Posted on Nov 18, 2009
Testimonial: "Thank you very much for your help."
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
What is the LENGTH And width of the drive belt on 2008 toro lx426
Acuatly there are two belts since is MTD style system.
5/8 x 90-1/2 MTD number 9540467A
5/8 x 42 MTD number 9540468
Apr 28, 2015 | Toro Garden
Blades will not engage on toro LX426 Lawn Tractor
Either The drive belt for the blades has come off, or it has broken.
Jul 03, 2014 | Toro Lawn Mower With Toro Power Tools
How do I change the drive belt on a Toro LX466? Also, what would cause this lawn tractor to go thru one drive belt a year since 2008?
well I have a Lx 500 and the problem is that the bearings on the pulley shafts are wore out, makin the pulleys hard to turn or dragging heating up your belt. It heats up from the friction of the pulleys not free spinning like they should. next time you have the belt off check out the pulleys and see if they spin freely that will be the tale tell sign.
May 04, 2011 | Toro LX466 22HP Lawn Tractor 13RT61RH244
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
2,513 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
