Question about Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 printing blank pages after fuser, toner, and drum was changed
I have a Brother MFC 6800 printer. The printer had light vertical places on the printout. From past experiences, this has been the fuser. I changed out the fuser and it only prints out blank pages now. No toner is on the page. I put the old fuser back in and it does the same thing. I changed out the toner cartidge and drum. Still printing blank pages. Any suggestions???
  • Anonymous Aug 19, 2008
    same problem
Hi
i have the same problem after replace the fuser
the problem is in the little board ,where all the connectors are on
the , 7812a , a positive voltage regulator ,was loose ,
only resoldering and ok..!
excuse my english, i write from el salvador , im really never speak english, but i just try to help
reggards..!
carlos c.
Posted on May 22, 2009
  • Charly Karpenter May 26, 2009
    by the way...check the board conectors of the fuser...maybe you need to clean this little board down the printer....under a plate
    check it..if you move before....
    i think , in my case ..this is the really problem of the blank page....a bad polarisation or contac....but i dismounting to many times the covers...so i break the soldering of the regulator..(the stepper supply voltage..)
    i have many experience working whit hp equipments , since i work whit a hp dealer...and this problem in hp ,,is the same...a bad contac of high voltage....
SOURCE:
I have a Brother MFC-7340 and recently replace the toner and now the background is dirty looking when I print, ie grey where it should be white! What can I do to clean it up? Thanks!!
Either you purchased a a bad quality remanufactured toner cartridge or your fuser film is damaged.
If there is some kind of debris in black color that is on printouts, your fuser film might be damaged. Have a printer technician replace it.
If there is no debris, only bad quality printouts, it's the toner cartridge that needs replacement.
Mar 05, 2011 | Brother MFC-7340 All-In-One Laser Printer
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
All printouts have a 3/8 inch wide light vertical line -
Try an old toner cartridge if you have one. Does it do it when you use the copier function. Steven 805-520-3003
May 12, 2010 | Brother MFC 9700 All-In-One Laser Printer
Brother MFC-6800 - Mysterious Vertical Lines
This unit has a brom tube unit and need to be replacement . By repair tec.
Oct 05, 2009 | Brother Multi-Function Center MFC-240C...
Printout from Brother MFC8460N has vertical faded line across page
Try replacing the toner and if it still happens then you have a bad fuser. But im pretty sure its a faulty toner.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
Black Vertical line on copies using MFC-8660DN
Vertical lines mean it is being caused by one of the rollers within the printer. This is usually either the toner cartridge or the fuser assembly. I would try changing out the toner cartridge first even if it is new as sometimes they are DOA and they are much cheaper than the fuser assemblies. If that doesn't work, probably the fuser assembly.
Jun 05, 2009 | Brother MFC-8860DN Printer
Program sending address on brother mfc-6800
The settings should be able to be changed one of two ways. Either under fax settings on the printers menu, or under fax settings under the printer properties panel on the computer.
Mar 10, 2009 | Brother MFC 6800 All-In-One Laser Printer
Problem when printing
Have you changed out the drum? Sound like a drum problem
Feb 12, 2008 | Brother MFC 6800 All-In-One Laser Printer
Replaced both toner and drum- prints too light
remove drom and toner, in base of machine is a glass slit, clean it.
Oct 14, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother MFC 6800 All-In-One Laser Printer Logo
931 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
