Question about Troy Bilt 5.5hp Self Propelled Mower
My mower (12av5560711183621) runs for about 10 minutes then dies. I noticed that the muffler got really hot after only about 5-7 seconds of operation, that leads me to believe that after 10 minutes it gets to hot and maybe vaporizes the gas. what do I do? thank you
  • 420 Answers
If the motor kicks (jerks the starter rope out of your hands) when you try to restart the motor after it has stopped the cause could be overheating. Make sure the oil level is correct, remove the rewind cover and make sure all of the cooling fins are cleaned out.
Posted on May 27, 2010
John Deere weed eater problems
remove the muffler and run it if it runs good after that open the muffler and clean the screen inside
Apr 01, 2012 | Garden
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
Oil is fine, runs fine for about 10 minutes then bogs down and dies. Let it sit for 10 minutes it will start again and run fine for another 10 minutes. Used to be 20 minutes, then 15. The cooler the...
It could easily be an electrical issue, or not. Get a spark tester (hooks up to the spark plug). Pep boys, Autozone, and Napa all sell them for less than $10. Check for spark when the mower has quit. If no spark, most likely need to replace the ignition module. Also check the flywheel key, if it is has been sheared or even knicked, the engine will run hot.
If you still have spark when engine has failed, check the vent on the gas cap. A clogged vent will cause a vacuum to form in the tank and stall the engine.
Aug 23, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
B&S engine backfires, runs better with choke 1/2 out under load??
Check your rockers inside valve covers. They some time work loose. If they are loose the push rod will fall off rocker and cause the problem.
May 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Wont stay running
Hello:
Soak and Clean the Carburetor.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Toro Lawn Mower With Toro Power Tools
My 89 Honda Accord LX 5 speed wants to die when its in neutral after being warmed up and drove for about 10 minutes, or I drop it down into second around a corner. I just had the muffler and exhaust fixed...
if you didn't have the exhaust replaced by a shop , I would check to see that the flow direction on the new muffler is correct. It should have an arrow indicating which way the flow direction is supposed to be right on the muffler itself. A muffler hooked up backwards would cause excessive back pressure and cause this type of symptom.
Let me know if you need any more on this.
Nov 18, 2008 | Honda Accord Cars & Trucks
Troy Bilt 5.5hp Self Propelled Mower Logo
316 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
