Question about Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB Gas Kitchen Range
Oven No Heat, Gas Smell Amana AGS780WW
Amana oven HSI currrent is 2.75 amps. Very low or no flames and gas smell. What is expected current for AGS780WW Range?
3 Suggested Answers
SOURCE: smell gas when range is not in use
i have the same problem with a 2 year old stove, it was leaking from the safty valve, that is the part that the oven burner sits on, which is located in side the broiler drower when you remove it, it's on tha back middle lower section of that opening.
Posted on Dec 08, 2008
SOURCE: amana gas range will not heat in "bake" mode.
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
My galaxy range model 790.60012604. The oven do not heat up . The element is lite up but the oven burner do not flame up which leaves a gas smell.
You need a new igniter, it may glow, but is probably not drawing the exact amperage required to open the gas valve decisively... You should also check burner tube and orifice for spider webs or other obstructions... Kenmore Range Stove Oven Igniter 316489402
Jul 05, 2016 | Galaxy Kitchen Ranges
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Whirpool gas range - propane gas not sure oven is working right
First, the flame should be blue and without much visible yellow. You need to give the gas tube a good cleaning to get out any soot buildup and any partial obstuctions that might be causing the problem. Since you started with a yellow flame and soot, you need to get the burner tubes clean to see if you have resolved the problem after adjusting the regulator and burner valve(s).
You might need to install a different regulator to match the pressure of your gas supply source, as regulators have a specific working range of inlet (supply gas pressure) that they can operate properly at to "regulate" the supply pressure to the stove's needed pressure.
Check your manual and the installation guide to verify what the gas inlet pressure requirements are and check with your gas supplier to see what they are providing you.
To your 2nd question, yes, the gas will cycle on and off when you are using the oven, since the thermostat will call for more heat when needed and shut off the gas/flame once the temperature you set the control at, has been reached. The cycling is a result of the oven trying to maintain the desired temperature for baking.
One reason that you can smell gas when the oven is being used, is because all gas ovens have a surface vent to allow excess heat to escape from the oven compartment, however you should not be smelling raw gas (actually you're smelling the "rotten egg" additive that's put in the gas) all the time, since when the oven is turned on, a small electric ignitor is heated up VERY HOT glowing bright orange inside the oven compartment. Once it's hot enough a sensor opens the gas valve and lets gas into the burner tube to be ignited instantly by the VERY HOT ignitor. It is rare to smell raw gas with this system, but sometimes you'll get a stronger "rotten egg" smell at different times due to the gas company and their system, etc.
As to the gas smell, you should NOT be smelling gas every time the oven cycles on when baking, as a normal ongoing occurrence. During the first few uses, it is normal to smell some gas, but this should go away after a couple of uses. If it doesn't, you should look to make sure the regulator and oven controls are PROPERLY configured and set - Since you've already fiddled with these, it's probably a good idea to have someone from your gas company (or a gas appliance tech) come out and do this. Improper settings can cause some serious problems.
Hope this helps!
Jul 15, 2009 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven won't come on
check the ignitor for the oven even it is glowing it may not be pulling enough amps to call for gas this is a very common problem with maytag and amana ranges replace the ignitor and it should work fine
Jul 12, 2009 | Amana RanARG7302 Gas Kitchen Range
Frigidaire gas oven not heating
replace the bake ignitor its getting weak
Jul 01, 2009 | Frigidaire FGB24T3A Gas Single Oven
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Trouble with an Amana oven
check the door switch
check the termocouple
hamid
hhamidi56@hotmail.com
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
Ge jbgp24
I seem to be working on the same problem. What I found bothers me. As a safety feature, the hot surface igniter, (HSI), is in series with the gas valve. If the HSI is dead, then there is no gas flow, which is a good thing. However, if the HSI has increased in resistance, as mine has, it still allows the gas valve to open partially. Not quite enough gas flow to support an ignition but, enough to allow gas to escape. I would suspect your HSI increases resistance after you get a flame causing the gas valve to close long enough for the flame to stop, then the HSI decreases it's resistance enough to allow the gas valve to partially open. Please verify this on your own as I am just a regular home owner myself.
Sep 03, 2007 | GE JGBP24 Gas Kitchen Range
Amana AGS1740BDW / AGS1740BDQ / AGS1740BDB Gas Kitchen Range Logo
114 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
