Question about Motorola Mobility Moto Q
Freezing up frequently - Motorola Mobility Moto Q
  • 2,335 Answers
I can help you with your Motorola Moto Q freezing up problem.
What has most likely happened is that the firmware of your phone has become corrupted. When this happens your phone will freeze, lock up, or be unable to start up.
This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware.
The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.)
If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times.
My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone.
I hope that helps.
_________________________________________________
Motorola MotoQ Manual Download
Motorola MotoQ Update Manual Download
Motorola MotoQ Verizon Firmware Update Download
Posted on Jul 14, 2010
My samsung galaxy s6 edge is about 15 months old. it switches itself on and off, freezes frequently, and gets very hot. can you help?
I would try a factory reset. Make sure you back up all data as it will be lost. If that doesn't work the a new battery would be next. If it continues to act up then you have a hardware problem and it needs to be repaired.
Aug 19, 2016 | Samsung Galaxy S6 Edge
Model mmf49-1-w is freezing and thawing too frequently
Is the compressor getting hot while this is happening? Make sure all the fans are running strong check the capacitor and the start relay that may be causing this
APPLIANCE 911
Jun 04, 2016 | Refrigerators
Frequent crashes and long loading times. operating system is Windows 7. DVD drive does not display. hangs up frequently during booting
I think at this point, you should consider using your recovery disc if you have one before the system freezes up.
Mar 21, 2011 | Computers & Internet
My pc frequently freezes and runs slow. How can I stop this?
defragment pc once every 15 days. uninstall unnecessary pgms.
May 21, 2010 | HP Compaq Presario SR2150NX PC Desktop
The coils freezes up frequently. Most recently,
If your defrost timer is not working then you will have problems with freezing the coils. When it is humid out and you are in and out of the unit the problem will be worse. To eliminate this problem you will need to get and install the timer. Do a search for "appliance parts" and checkout a number of the suppliers as the prices can vary a lot. All you need to find your part is the model # and sometimes serial# of your unit.
Nov 19, 2009 | Master Bilt Master-Bilt MPM-72 7.9 Cu. Ft....
My ps3 game freezes frequently
you should upgrade your firmware,that will solve the problem
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Food freezing in refrigerator storage bins
produce has more water in it to freeze. Try turning down the temp in the fridge part of the unit you may try putting a termometer in there to gauge where it should be adjusted to, about 38-41 degrees is a safe temp for keeping food.
May 27, 2009 | Refrigerators
Dell Dimension 2400 Freezes frequently
check inside the case of the computer to make sure that the interface cable between the hard drive and the motherboard are fully connected. Also check to see if the RAM modules are fully inserted into their slots. If not, they try removing them one by one, until the computer starts up faster. If this doesn't fix it, then try a new hard drive, and interface cable.
Feb 21, 2008 | Dell Dimension 2400 PC Desktop
Frequent freezing of mouse,and unexpected shut down
the mouse is freezing because, you have either too many programmes running at start up, conflicting drivers, slow start up anti virus programmes, or you may have a virus or trojan/spyware programme running in the background. The shut down could be a processor overheating problem, so check all your vents and fans for clogged up dust and ensure your pc is well ventillated.
Mar 30, 2007 | Compaq Evo N800C: Evo N800c P4 M-1.7GHz,...
Freezing
The freezing may be because the logs are full. I had this issue and then set the log levels to "7 days". Everything worked well after that. I found this solution on some other website.
Press "Cntl-Shift-L" and then press Menu. Under "Tools" you will find the option to set Log Duration. Before that, you should clear your log. Hope this helps.
Jan 14, 2007 | Nokia 9300 Handheld
Open Questions:
boot_c_03.08.00r_mpap Paul Sager from FixYa has posted a solution for this problem previousley (as below). I have tried the Motorola and Verizon sites (tried the store as well) and the software is not available to flash the phone. Do you know of a site that would still have it available? Or can this question be sent to Paul to further comment on it? All I want to do is recover the phone numbers, notes and calandar from the phone via Activesync or Windows. Paul Sager 2335 Solutions July 14, 2010 I can help you with your Motorola Moto Q. What has happened is that the firmware of your phone has become corrupted. When this happens your phone will no longer finish its boot sequence. This is a very common situation with many phones: in fact, much of what I do here at Fixya is explain how people can fix their MP3 players, GPS and phones by reflashing the firmware. The good news is that if you take your phone into your carrier's store, they can reflash it for you right there (if they have a competent tech handy.) If you are comfortable with computers etc, you can also do it yourself. Your computer will communicate with and fix your phone, even though it doesn't seem to recognize it right now - I've seen this many many times. My only warning for you is that if you are going to flash your phone yourself, you need to get the correct firmware from motorola's site for your carrier. I just downloaded the Verizon firmware as an example - Motorola's website has about ten different carrier firmwares for their MotoQ phone. I hope that helps.
Oct 09, 2012 | Motorola Mobility Moto Q
See all Motorola Mobility Moto Q Questions
Motorola Mobility Moto Q Logo
100 people viewed this question
Top Motorola Mobility Computers & Internet Experts
AJMAL KHAN
Tom Chichester
Abby Carter
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
