Question about Acer NSK8458AN Keyboard
My volume wheel isn't working, as well as the mute button. Model SK-9625. The computer is Acer Aspire X1300. Using headphones, Sony Dynamic Stereo Headphones MDR-V150. Speakers not plugged in, since I always use headphones.
I had the same problem. For me it helped to turn on Hotkey utility (was already installed). If you do not have it, try to google it.
Hope it helps
Posted on Jan 03, 2011
I can't turn up the volume n my laptop
Which operating system ?
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers. These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop. If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse.
Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control. Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting. Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume. Be sure the speaker icon below each control is not accidentally muted. Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio. Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar. Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category. Hope this helps
Dec 10, 2012 | Acer Aspire 7741z-5731 17.3" 1.86ghz P6000...
No audio on acer aspire x1800
You can try updating your drivers. Go to your control panel and search for "device manager". Then find the audio devices section and click on each of them one at a time and select "search for driver updates". This should help with your problem.
Jun 22, 2017 | Acer New Aspire X1200 X1300 X1301 X1800...
I'm running windows xp/sp2 on Acer Aspire 3000 laptop. I've had sound working just fine ever since I got this machine, but just sometime in the past two weeks it has quit on me. When I open the volume...
first of all change the play back set from head phone in the audio tab and see if there is mute option on on the speakers symbol on the system tray bottom right hand on the system if yes uncheck the mute
Oct 26, 2010 | Acer Aspire 3000 Notebook
Acer keyboard sk-9625 multimedia keys don't work
if the programmable keys are not working, then likely the correct driver is not in use.
what is the make/model ? Go to the Device Manager and see if the Keyboard is being identified correctly or if just the Generic windows KB driver is being used.
Oct 20, 2010 | Acer Aspire AM3802U9062 (PTSCR02009) PC...
I'm using ACER ASPIRE 2920Z. my ACER CRYSTAL EYEWEBCAM is working when i'm using it for video calling but if i use it just to take photos it's not working. the screen comes out but it doesn't show any...
Please find the below steps to access Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys.
If the the above steps are not working, then follow the below steps:
You can reinstall the WebCam drivers from the Acer recovery management, to do so:
Start Menu> All Programs> Acer erecovery management> Restore> Restore Application & Drivers> Contents> Select Acer Crystal Eye and install it
OR
Got to http://gd.panam.acer.com/home/
Select the computer model
Select Operating System
Click Drivers
Select Camera (Suyin) and download it.
Once downloaded install it on your computer.
If still facing the issue, then you may need to perform full system recovery, to do so please follow the steps mentioned below
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Sep 19, 2010 | Acer Aspire 4520-5582 Notebook
I can barely hear anything, from a video in an email or something on you tube, the volume is all the way up but it isn't a third as loud as my dell. HELP
The suggestions in the manual may not help. Go to the Acer site and make sure that you have the latest audio driver. There is considerable chatter in the forums about unsatisfactory volume in that model.
The manual may be downloaded at: http://support.acer.com/acerpanam/manuals/acer/0000/userguides/AS5600_3680_UG.pdf
The manual gives the following answer:
No audio is heard from the computer. Check the following: • The volume may be muted. In Windows, look at the volume control (speaker) icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute all option. • The volume level may be too low. In Windows, look at the volume control icon on the taskbar. You can also use the volume control buttons to adjust the volume. See "Hotkeys" on page 30 for more detail. • If headphones, earphones or external speakers are connected to the lineout port on the computer, the internal speakers automatically turn off.
May 01, 2010 | Acer Aspire 3680 Laptop
No sound
Make sure your sound button isn't on mute and the volume is all the way up. Make sure if there in a volume button on your headphones that it is not muted or played really quietly.
Oct 18, 2009 | Acer Aspire One PC Notebook
How can i set up the microphone on my acer ( aspire 3680 )
Go to Start - Control Panel - Sound - Recording - Recording and you will see a list of connected devices. Check that the Microphone is live and has a green tick and also that the driver name is present. Double click or Right Click the Microphone for setup options. If it is not working you may have to reinstall the sound driver.
If this is not working then check Start - Control Panel - Device Manager - Sound, Video and Game Controllers to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
Also check Start - Control Panel - Device Manager - System Devices to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
If there are no errors then you should be able to use the microphone successfully.
The volume may be muted. In Windows, look at the volume control icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute option.
• The volume level may be too low. In Windows, click on the volume control icon on the taskbar, and then use the slider control to increase the volume level.
• If headphones are connected to the headphone jack on the computer, your computer's built-in speakers will be turned off.
Oct 02, 2009 | Acer Aspire 3680 Laptop
Acer NSK8458AN Keyboard Logo
592 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
