Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Does my Skil #77 gear drive saw require only Skil oil, or is it okay to use synthetic (automotive) 75W-90 GL5 hypoid gear oil, such as Mobil 1?
  • 1 more comment
  • mjwillis401 Jun 05, 2010
    Thanks for the advice. I also searched through a great number of pages on Google and found a professional carpenter who said that after extended constant use, his model 77 would begin to smoke when hypoid gear oil was in it. He went back to Skil oil and the saw never smoked again. Based on that, I will continue to use Skil oil in my saw.
  • mjwillis401 Jun 06, 2010
    Thank you for the further clarification. No, he didn't mention the source of the smoke - but the discussion was about oil, and the saw continued to work normally, and it no longer smoked when he switched back to Skil oil - so I can only assume it was not electrical. I may never get my saw that hot, though I have gotten it pretty warm when ripping several lengths of rough (full dimension) 2x12 redwood.
  • 1,498 Answers
Hi MJ,
Either is fine.
The concern is not mixing them.
It should be one or the other, not both.
Best regards,
Mike
Posted on May 26, 2010
  • Justin Case
    Justin Case Jun 06, 2010
    Hello again MJ,
    Interesting tidbit. Did he mention if the source of the smoke (electrical vs hot oil)?
    Unlike the differential in a vehicle where the gearing is meant to function at a relatively slow speed, the gear drive in your saw is quite high.
    Mixing synthetic and standard in a high speed environment will result in an emulsification of air and the oils. Like whipping cream.
    The trapped air lessens both the lubricating and heat dissipating attributes of the oil. With extended use the the device will
    become hotter faster and retain that heat longer when both oils are present than with just one or the other.
    I have seen 'Whipped' oil in high performance engines (not water and oil, but air and oil) as a result of the mixing of the two types.
    As I said, interesting.
    Mike
What type of oil do I use in the drive shaft of my 1994 honda shadow 1100. I have heard 90w, but have read on here to use other oils. What would be the best.
The final drive should use 80/90 hypoid gear oil for the worm gears. If you would like the final drive to run cooler (less friction) use synthetic hypoid gear oil. Use synthetic 80/90 hypoid gear oil and change it every other motor oil change.
Sep 26, 2011 | 1994 Honda VT 1100 C Shadow
I have a 79 yamaha xs750 special what kind of fluid do I put in the transmission and how much?
The transmission oil and the engine oil are the same. Use only a JASO MA certified motorcycle oil. Automotive oil uses different additives and will shorten the life of your wet clutch and transmission gears. 10w-40 oil is good for cold climate. 20w-50 for hot climate/touring. Synthetic oil will make your cycle run cooler and shift easier. Your final drive uses 80/90 hypoid gear oil. Synthetic hypoid oil will reduce friction and make your final drive run cooler. You will probably need four quarts of oil . Pour in three quarts and check the oil level. Top up as needed. If changing the oil filter you will have to run the motor to get an accurate oil level reading
Dec 24, 2010 | 1978 Yamaha XS 650 SE
Rear gear oil what kind do i need
The rear differential takes a SAE 80W-90 GL5 Gear Oil. You can also use 75W-90, and synthetic equivalents can also be used.
Dec 14, 2010 | 1997 Cadillac Catera
What kind of transmission oil carries the manual aidi a4 2000
The transmission oil type for Audi A4 MY 2000 with manual gearbox is:
Synthetic oil SAE 75 W 90, part number G 052 145 S2 (1 liter).
Example:
Castrol Syntrax 75W-90 Full synthetic SAE 75W/90, API GL5. manual transmission, transaxle and rear axle lubricant with outstanding extreme pressure, synchroniser and high temperature performance.
Oct 16, 2010 | Audi A4 Cars & Trucks
Rear end gear lub spec
80w-90 hypoid gear oil GL5, I recommend synthetic, it will decrease friction, increase gear life, and run cooler over the long miles.
Jul 17, 2010 | 2008 Honda GL 1800 Gold wing Deluxe
How many quarts needed for 2004 toyota automatic
Transmission 2.1qts
Front diff 1.2qts takes 75w-90 Hypoid gear oil
Rear diff 3.9 qts of 75w-90 synthetic oil
Transfer case 1.3 qts of a Hypoid gear oil API GL-4 or GL-5
Jul 02, 2010 | 2003 Toyota Sequoia
For the Skil 77 worm drive circular saws what type of oil is required?
Use 90 weight gear/differential oil but if you use it outside in the cold weather it's too thick, use 40 weight oil then and switch to the 90 weight in the summer.
Jun 03, 2010 | Saws
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
677 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
