Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
If I plan to move this TV is there any pre preparation before moving thanks john
    President:
  • 788 Answers
Yes there is, and I am glad that you asked. Too many ask for repairs after the move.
First I would unplug the set and allow it to cool down for at least four hours, overnight would be best. I would get some thin foam and wrap it around the front bezel. Then place the largest piece of cardboard that you can find, maybe from an appliance store, and place that over the front screens.
Then shrink wrap the entire unit from top to bottom, and do not allow this unit to lay on its back or sides.
That should help.
If you need any more input.
Please respond to this post.
asnowman
Posted on May 27, 2010
Who Should Write My Business Strategy Plan?
writing business plan is not big deal.
Nov 02, 2015 | Retail Supplies
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
Whast are the necessary tips of moving?
Planning is the most necessary tip of moving doesn't matter what you move, only matter your effective plan,
In planning part, hiring and consulting with removals company makes your move hassle free.
Removal company
That company reaaly helpful also well known in UK Society.
Dec 27, 2012 | Computers & Internet
I have a 65H84 model TV and plan on moving it to a different room. This TV was in place when we bought the house from previous owners. Does the unit come a part in two sections for easier moving? Thank...
No,this thing come in as a whole tv unit,dosen't come aparts.U check the tv,see if it work,before going all the troubles moving it to another room.These DLP tvs design are notorious for it tv convergence problems and DM power supply board intermittently shutdowns alots.It bulky design and not work for free DTV over the air.
Feb 08, 2011 | Toshiba 65H84 65" Rear Projection HDTV
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
DGTEC top box,DG -HD8710, lost manual when moving
The main aerial goes into the box,then a flylead out of the box into the tv(if you have a vcr or dvd rec then it will go in there first then out into the tv).Then connect the box to the tv with a scart lead.
Nov 07, 2009 | Televison & Video
Screen has shifted to the right by 8mm
With the remote I managed to get into the correct menu for the screen (previously I was mistakenly in the OSD menue.
Thanks
John
May 17, 2009 | Videoseven LTV17D 17 in. HDTV-Ready LCD...
Moving abroad
you would need a power converter Europes power runs on 50hz power were the u.s. uses 60hz if you plug your tv in in Europe you will damage it without a converter
Apr 27, 2009 | Televison & Video
Can I move this TV on a trailer?
You would be best moving it on a truck, vs. a trailer. I know that height is a concern, but this damage due to debris can be minimized by judicious use of refrigerator boxes (see local sears store) to protect it.
Either way, plan on having to realign the screen when you finally get it moved. This is normal. Moving on a trailer just might permanently misalign the screen so that the processor in the tv cannot compensate for it.
UHaul also rents blankets / pads without having to rent anything else as well. You might consider that option.
On the other hand, this tv was likely trucked across America inside a trailer on the back of a semi. But that trailer also had a lot more weight in it as well. Personally, I would move it using a pickup.
Dec 21, 2008 | Toshiba 57H81 57" Rear Projection...
Phono stage
Hi. The phono input of your STRBD930 has a pre amplifier on it, and as such should only be connected to a dynamic phono cartridge. This is one which has a moving coil or magnet, as opposed to a piezzo cartridge. Connecting a piezzo turn table to the phono input will provide a too-higher voltage input for the pre amp, which might damage the pre amp. I hope this helps. PS moving magnet and moving coil are same difference. These are both dynamic cartridges, and can be connected to STRDB930.
Jul 07, 2008 | Sony STR-DB930 Receiver
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
