Question about Hoover U5227-930 Elite Upright Vacuum
Replacing leaf spring Hoover wheels
The leaf spring has come out of our Hoover U5227-930 and I can't quite figure out how to put it back so that it will work properly. I see a slot where I think one end of the clip goes but when I put the wheels back on it doesn't feel right. Any suggestions on how the clip goes in??
  • 4 more comments
  • handy_mikey Jun 30, 2008
    Same situation. Was trying to remove the beater bar cover and the metal clip popped out along with the wheels....
  • Jack76 Nov 09, 2008
    I have the same problem with the leaf spring on the wheel height adjustment assembly. Can someone please post a picture of the correct installation or somehow explain how it goes back on? Thanks.
  • Anonymous Dec 29, 2008
    Same problem, was replacing the belt and the height adjustment wheels clip popped off and I can't figure out how to get it back together.
  • lisaanne Feb 06, 2009
    I have the same issue reattaching the metal clip and wheels on my Hoover! Please help! Thanks
    Need to replace metal clip and reattach wheels. Please help!
  • Lee Eismann May 11, 2010
    Are you talking about a small, metal clip that attaches to the smaller set of wheels that act as the carpet adjuster?
    Novelist:
  • 88 Answers
If people are still having this problem, please post here and I will take a picture of the correct placement for the metal clip.
Posted on Jul 19, 2008
  • tc_charlie Jun 06, 2011
    I have the old U5227. I popped the leaf spring out and can't figure out how to get it back in place. Can you please post the photo of how it is supposed to look? Barbara
  • Lee Eismann Jun 06, 2011
    I will take the pictures tonight, Monday, 06/06/11, and post them tomorrow.
SOURCE:
My floormate leaks water on the floor in puddles, even when I am not holding down the lever to wash.
Ok when replacing the Spring stem and rubber seal. Put the spring on the stem set it in the hole of the solution tank carefully hold it steady then pull the stem out slip the rubber seal onto the stem with the cupped side facing down toward inside of the tank press it over the rim on the stem so it stays in place then take the stem slip it into the solution tanks hole inside the spring and press the rubber seal into the inside of the tank.
I posted this so no one else goes threw the trouble I went through until I figured it out for my self I lost the parts and did not remember how the thing went back together and could find no help anywhere. Good Luck, Ray
May 26, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
The wheels with the spring broke off and I'm trying to put a new one on but I don't know where the spring goes.
This spring can be very confusing to install. It slides onto the wheel assembly near where the attaching pin is longer ( there are flat protrusions on both sides of the wheel assembly). One end of the spring pushes up on the assembly when it is in place, and the free end must be pulled down and inserted into the small slot in the bottom of the base. Pull down on the shorter end of the spring, holding the longer end, and slide it onto the round area on the wheel assembly. As you put the wheels back on, pull on the longer end and insert it into the slot in the base.
Jan 24, 2011 | Hoover Tempo Widepath Upright Vacuum -...
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
How to install spring
on this machine the spring goes to the front wheel assembly under the machine. if this has came off then the wheel assembly is broken. i believe the part # is 36432027. hope this helps
Jul 27, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel Bagless bolt fell off
With this self propell series, the entire bottom needs to come apart to re-install the nut. if it is one month old I would highly recommend taking it in for warranty service. What plastic is melted?
Nov 02, 2008 | Hoover U6630-900 WindTunnel Bagless...
Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Wheel carrier spring
What is the correct model number???
Feb 23, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover problem
The metal clip is a leaf spring and there is a slot for it, You may have to pull the cover off, may have a broken piece for the adjuster. Would help to have model number.
Feb 17, 2008 | Vacuums
Replacing the belt
u have 2 articulate the belt so that u can get it sideways there is just enough space between the pulley and the plastic after u get it in bring the roller brush close enough to put the belt around it then stretch it back to the slots for the roller
maybe that will help
Feb 04, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover U5227-930 Elite Upright Vacuum Logo
450 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Kirk Thompson
Level 1 Expert
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
