Question about Gyration gp210001 Mouse
My mouse batteries are dead and there seems to be no replacements available. Can the unit be taken apart and the battery inside replaced?
    Genius:
  • 1,189 Answers
Posted on May 26, 2010
Bad RTC Chip, I read your solution, where is the battery? I can not seem to re-boot the unit.
Hi the Battery for this units is inside the machine and the only way to replace it is by taking the unit apart BUT it will come up whit tamper or bad RTC you need to send the unit to get the battery replace if you need more help call us @ 775-358-2922 :- )
Sep 19, 2011 | VeriFone Omni 3700
I took my computer in to get worked on- now when I power up- the wireless keyboard and mouse don't work. When I type or move the mouse- a light flashes on the antenna part that's connected to the...
why not use a wired mouse and keyboard, bam fixed.
or replace the batteries in both.
the batteries, are short lived. replace them first.
NO OS STATED, XP"???????????????????????
what is a p5304????
to make anything run on XP. (its dead)
is hard,
you get to wade through 1000s of web sites, (not HP)
finding drivers that are not infected.
why post without PC full model stated
like this, COMPAQ desktop, model, bla bla off the service tag.
then the OS< we cant guess any of this, and is 100% key to the success of these failures, and more.
all wireless devices use a battery,
so the mouse can transmit its actions on the Radio channel
no battery no RF radios possible.
the keyboard too, needs power, and that power is a battery inside
and most PC this old (relic) no battery lasts this long.
if the battery dont fix it, try a new mouse keyboard.
end the horror of batteries, and XP, and driver same.
XP is dead. as is vista
so plug and play is no help here. its now DEAD for XP/VISTA
W7 might work, try that? after new batteries.... for SURE.
Aug 20, 2017 | Compaq Wireless Keyboard/Mouse p5304
I'm currently using a 2.4 GHz wireless optical mouse product number WR564A. Recently the mouse has stopped working in an odd fashion. The button in the mouse wheel flashes as if the batteries are low,...
its got a battery, replace it?
that small pieces is USB , and uses USB power to work
the mouse has a battery.
page to in your hp manuals states
single AA battery lasts 6months.
http://h10032.www1.hp.com/ctg/Manual/c02542571
Mar 12, 2017 | HP Wireless Optical Mouse
The Logitech EX100 optical mouse seems to be dead. How do I replace the battery, or can I?
Hello, The battery compartment is located at the bottom of your mouse. Chances are that you need one AAA battery to replace it.
Feb 28, 2011 | Logitech Cordless Desktop Ex100
My hp wireless mouse quit new battery's, reboot pc, reset mouse button, no light, seems dead "-(
HI there,
There is one sure-fire way to see if your mouse is alive. Plug its wireless receiver into a different computer and see if it works on that one. If it does, then you know that the USB port on the computer you usually use has the problem.
If it won't work on another computer then the sending unit inside the mouse, or the receiving unit you plug into the USB port is dead.
Best Regards,
Marcus
Sep 14, 2010 | HP Computers & Internet
Microsoft wireless notebook laser mouse 6000 not working
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still no workie. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the mouse's opening for the battery appeared to be bent down (away from the contact on the battery tray). So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Jun 26, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless logitech mouse does not work
Going from memory, I think you have to remove the small rubber pads on the underside. On some types, you would also have to remove the model label on the underside. This should expose the screws to take it apart.
The cordless mouse uses Lithium chargeable batteries. Don't put standard type non chargeable batteries inside.
You may find the cost of the proper batteries to come close to the replacement value of the mouse.
Jerry G.
Apr 15, 2008 | GE JASHO97985 Mouse
Powersaver R7 wireless keyboard and mouse
how to connect r7-10 mouse to pc ?do i press something?
Dec 29, 2007 | A4tech A-Shape Keyboard/Optical Mouse...
Mouse left click button does not always make contact.
Hi RPM GUY, I have a couple of these too but what you?re describing is just the button wearing out from lots of use. Since it?s less than one year old it probably still under warranty, taking it apart would definitely void it. I would contact Microsoft hardware support and try for a warranty replacement. If you want to go ahead anyway remove the 2x batteries and you will see a screw inbetween. Remove it and the bottom half will come appart. Let us know if you have any other questions and please don?t forget to rate the post.
Feb 01, 2007 | Microsoft Wireless Optical Mouse
Batteries replacement
The piece of plastic where your palm would rest on the mouse is the compartment for the batteries. The piece of plastic has the GE logo on it. You need to slide the piece of plastic away from the direction of the mouse buttons. You will then be able to put the batteries inside and slip the piece of plastic back on.
Jul 24, 2006 | GE 97985 Mouse
Gyration gp210001 Mouse Logo
313 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
solver2010
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
