Question about Continental Electric CE-AC7581 Ductless Mini Split System Air Conditioner
My AC is blowing hot instead of cold air, what can i do
  • 901 Answers
Compressor not getting power. Or not functioning. Take assistance from the service provider. you have to check all the relays and commands which may be difficult!
Posted on May 27, 2010
2 Suggested Answers
  • 77 Answers
SOURCE: ac BLOWING HOT AIR INSTEAD OF COLD
Check to see if your outside unit is running. If not, check the breaker. If it is running you may have an issue with the reversing valve. It looks like three lines coming out of the top and one on the bottom. Trace the wires back to see that they are tight and secure. Of course, TURN OFF THE POWER first. good luck.
Posted on Apr 18, 2009
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Why does my 2005 GMC truck air conditioner will blow cold air then hot air?
possibly low coolant, that will make the clutch disengaged and you get hot air instead,
Jul 22, 2014 | Heating & Cooling
My heater does not blow in floor in a dodgeram 1500
the heater vacuum motor and lines needs to be checked.Also get the blend door checked.
NO HEAT ON FLOOR VENTS
As per your problem mentioned. There are few solved help links to troubleshoot these problems. Go through the list and Click the link below:----
2000 Toyota Avalon: No heat on Passenger Side?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
No heat on Oldsmobile Silhouette?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
Hot air on the driver's side vents only?
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
Temperature gauge does not move and no heat when heater is ON?
http://technoanswers.blogspot.com/2012/01/temperature-gauge-does-not-move-and-no.html
1992 Toyota Camry: A/C Control light Flashing and A/C not Blowing Cold?
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
No heat, blower blows only cold?
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
Ford F150 Ac only blows through defrost vents?
http://technoanswers.blogspot.com/2012/01/forf-f150-ac-only-blows-through-defrost.html
Dodge A/C come out of defrost vents only?
http://technoanswers.blogspot.com/2012/01/dodge-ac-come-out-of-defrost-vents-only.html
Ac vacuum line on dodge cummins?
http://technoanswers.blogspot.com/2012/01/ac-vacuum-line-on-dodge-cummins.html
Ford ranger AC blows cold through defrost vents instead on cabin vents?
http://technoanswers.blogspot.com/2012/01/ford-ranger-ac-blows-cold-through.html
2005 Chrysler PT Cruiser: A/C Blows Warm?
http://whoisbyme.blogspot.in/2012/06/2005-chrysler-p8t-cruiser-ac-blows-warm.html
2009 Mercury Grand Marquis: A/C blows Cold From Defrost Vent Only?
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
AC not blowing through Vents on 2007 Chevy Trailblazer?
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
Passenger side temperature is warm air out of dash vents?
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
No heat from vents
Heater blows cold?
These will help.
Thanks.
Nov 28, 2012 | 2006 Ford Taurus
2004 mercury mountaineer.heat problem When turning ac knob to heat clicking sound like door opening and closing repeatedly sounds and air blows cold instead of hot.
Sep 13, 2010 | 2004 Mercury Mountaineer
2004 chevrolet avalanche A/C not staying cold, after a while goes warm
2004 chevy Avalanches air conditioner blows hot air, can the actuator be forced to keep it blowing cold air instead of hot air all the time.
Jul 20, 2010 | 2004 Chevrolet Avalanche
2001 dodge ram 1500 ac is blowing hot air instead of cold
Your A/C sounds like it needs to be vacuumed
out and then recharged to factory specs. That
should solve the problem.
Jun 30, 2009 | Dodge Ram 1500 Cars & Trucks
Ac BLOWING HOT AIR INSTEAD OF COLD. All of a sudden my AC started blowing hot air instead of cold. It is set on cool.
Apr 18, 2009 | Hunter 30124 Air Conditioner
Ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Mar 26, 2008 | Hunter 30124 Air Conditioner
Continental Electric CE-AC7581 Ductless Mini Split System Air Conditioner Logo
135 people viewed this question
Top Continental Heating & Cooling Experts
Tim Whalen
Donni Steen
Are you a Continental Heating and Cooling Expert? Answer questions, earn points and help others
