Question about Zenith Audio Players & Recorders
How to set time zenith 1251T - Zenith Audio Players & Recorders
How do you set the time on a Zenith Z1233ba
March 5, 2015.
I'm selling these Zenith Z1233BA Clock Radios
on ebay. I have sold about 10 without any problems, but someone just ask if I know where the get the instructions. I could not find the manual online.
Here are some of the basic.
To set the time set the lock button on the bottom to off, press the clock button, the clock will flash then use the set buttons on top to change the time. Use the <> to change the time, when the time is set press and hold the enter button until you hear a beep. You have to cycle through all the minutes to get to the next hour. Do the same to set the zone. And to set the Date select the CAL button and do the same as setting the time. Put it back on lock when the time, date and zone are set.
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the <> to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. To set the PRESETS tune the radio to the station you want to be a PRESET, then press and hold a PRESET button until you hear a beep.
Mar 09, 2014 | Zenith Audio Players & Recorders
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
Zenith tv rb50m88w shuts off without warning
Most likely there is a bad solder connection or connections somewhere in the set--not likely to be a do it yourself repair unless you have some skill in this area.
Jun 16, 2012 | Zenith Z44SZ80 Television
How to reset the lamp for Zenith D52WLCD
try this if you have the remote control, press the menu button continuously, The "OSD" menus will disappear then press the "9876" and press the "OK" button to enter "ADJ" mode you will see "Lamp Life Time" Then set the time to "00".
Jun 12, 2011 | Zenith D52WLCD 52" Rear Projection...
Set Time
that long snooze button on top lifts up and the time and alarm buttons are there to set it with...ive had a zenith clock radio just like it for over 10 yrs.. have fun,..
Nov 23, 2009 | Zenith Z228T Clock Radio
I need the switch on the back of the Zenith clock radio R472.
RADIO SHACK CAN HELP WITH AL KINDS OF SWITCHES.
DOCTOR FIX IT
Nov 03, 2009 | Audio Players & Recorders
16 yr old 25" Zenith..1st colors went yellow/lime now TV is dead
Absolutely not worth repair. You have described a classic symptom of Zenith picture tube failure, and about 99% of the time the main board in the TV is ruined as well. You've gotten good life from the set (manufacturers figure tube life is around 7 years these days), so it's time to replace it.
Apr 09, 2009 | Zenith B27A11Z 27" TV
Need operating manual for Zenith Model Z253W radio
1. Tune the radio to the frequency you want to preset, using the "Tuning/Set" buttons.
2. Press "Time Set" button to enter set mode. Note it says "Preset" below this button, because it is used to set both time set and presets.
3. Select the preset number you want, using the "Preset" buttons.
4. Press "Time Set" button again to exit set mode.
5. Repeat the above process for each preset.
Nov 15, 2008 | Zenith Audio Players & Recorders
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
73 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
xalint1
xalint1
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
