Have a compaq tower that i need to open but do not know how
  • Anonymous Jan 23, 2009
    i need to install more ram and not sure how to open the tower
    Problem Solver:
  • 14 Answers
Why do you want to open it ?and i can give you some tips but i need a model #
Posted on Apr 09, 2008
SOURCE:
On off button not working
We need to follow some Troubleshooting steps
power off the tower
disconnect the power cable
1.open the side panal of the tower
2.then open the front panal of the tower
3.the please toggle the power button from inside the tower
4.then put back the front and the side panal
connect back the power cable
restart the pc using the power button
it will start working
Jan 13, 2011 | HP Compaq Presario SR1830NX PC Desktop
HOW TO OPEN THE TOWER CASE OF THE COMPAQ PRESARIO SR2170NX TO ADD MORE MEMORY
This is how to open the tower case of the Compaq Presario SR2170NX:
John
Jun 26, 2010 | Compaq Computers & Internet
Opening the tower to add Ram memory
I happened to find a PDF on compaq's support site: if you use Ctrl+F in your web browser and put in DC5100MT it will take you down to the right place. Simply open this PDF if your favorite viewer and there's a whole series of images explaining how to take the panel off (page 4).
Jun 05, 2010 | Compaq Presario 5000 PC Desktop
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Booting error
This is One of the Known Issues on Hp Products...
There are Updates Released by Hp for Most of the Model facing this issue...
The Products for which the Solution (drivers) have been Released so far in the DX series are...
  • HP Compaq dx6100 Microtower PC
  • HP Compaq dx6100 Slim Tower PC
  • HP Compaq dx6120 Microtower PC
  • HP Compaq dx6120 Slim Tower Desktop PC
  • HP Compaq dx6128 Microtower PC
  • HP Compaq dx7200 Microtower PC
  • HP Compaq dx7200 Slim Tower PC
  • HP Compaq dx7208 Microtower PC
  • HP Compaq dx7300 Microtower PC
  • HP Compaq dx7300 Slim Tower PC
  • Your Product is not listed.
    You got to Report with the HP and they Will update you once they have a Driver for you,
    However what you can do is try and run BIOS update if Possible.(it may not be Possible in a Boot issue though).
    Jul 17, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
    I dont know how to open up the cas of my compaq to install the memory
    What is the model of your computer?
    Is it a tower?
    If it is a tower, look on the back of your case. Along the right side there should be two screws. Remove both screws, grasp the side of the case where you removed the screws, and slide the side backwards. The panel should lift right off.
    Apr 16, 2008 | Computers & Internet
    Tower
    You need to open up the tower and look for the CMOS reset on the motherboard.  Normally it is a 3 terminal jumpered pins very near the Lithium battery.
    Hope this be of some help/idea. Good luck and kind regards.
    Oct 26, 2007 | Compaq Presario 5000 PC Desktop
    No Power!!
    Double check the switch in the back of the pc on the power supply. If their is a switch, you can try it in both positions. It is possible their is no switch, older compaq's are iffy. The switch will be black. Also check the 110/230 switch. I don't know what country you live in, however you may need to make sure that switch is in the appropriate spot. 110 for USA and 220/230 for UK
    Also, try unplugging your pc. Let it set for about 1 minute. Plug it back in and try again.
    Oct 11, 2007 | Compaq Presario 5000 PC Desktop
    Compaq presario 5151 desktop cdrom drive removal
    Take off the other side panel and you should be able to get at the screws. Also, Compaq has a handy step-by step guide with animations to help. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07164&lc=en&cc=us&dlc=en&product=93108&lang=en
    Aug 29, 2007 | Computers & Internet
    Open Questions:
    SBCglobal MAil Contact NuMbER $%#@{1-/855/*536/*5666/}#[email protected] SERVICE This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
    Oct 16, 2019 | Best Computers & Internet
    AVAST TeCH SuPPoRT PHoNE {{18OO/-/8O31O69}} NuMbEr jkkxz This AVAST USA phone number is ranked #2 out of 2 because 7,728 AVAST USA customers tried our tools and information and gave us feedback a fter they called. The reason customers call # I:8OO:,:8O31069 is to reach the AVAST USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AVAST USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AVAST USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AVAST USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AVAST USA Calling AVAST USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AVAST USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AVAST USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AVAST USA's phone numbers against each other. Contacting AVAST USA in General While I8OO8O31O69 is AVAST USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AVAST USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AVAST USA.
    Computers & Internet Logo
    78 people viewed this question
    Ekse
    Alun Cox
