Question about RCA 25202RE3 Corded Phone
No Display Information
I have a brand new phone. I cannot get my display screen to reflect anything. No caller i.d., no menu information, no date or time information etc. I have subscribed to the necessary services through the local telephone company and all the features worked for a couple of days but just stopped working. Also none of the lights are lit up on the phone but I can make and receive calls. I have re-set the phone by unplugging everything and then plugging everything back up and removing the batteries and replacing the batteries however, the phone still will not provide any information in the display screen. The phone also will only beep instead of ringing when a call comes in.
  • ghirmai May 20, 2008
    I have a similar problem ... all it displays is
    date
    L1 00 New calls
    L2 00 New calls
    Replace batteries
    and it does not change to display incoming call number
The AC Power Adapter was not fully connected.
Posted on Apr 08, 2008
SOURCE:
Samsung e1100t codes
Software version: *#9999#
IMEI number: *#06#
Serial number: *#0001#
Battery status- Memory capacity : *#9998*246#
Debug screen: *#9998*324# - *#8999*324#
LCD kontrast: *#9998*523#
Vibration test: *#9998*842# - *#8999*842#
Alarm beeper - Ringtone test : *#9998*289# - *#8999*289#
Smiley: *#9125#
Software version: *#0837#
Display contrast: *#0523# - *#8999*523#
Battery info: *#0228# or *#8999*228#
Display storage capacity: *#8999*636#
Display SIM card information: *#8999*778#
Show date and alarm clock: *#8999*782#
The display during warning: *#8999*786#
Samsung hardware version: *#8999*837#
Show network information: *#8999*638#
Display received channel number and received intensity: *#8999*9266#
*#1111# S/W Version
*#1234# Firmware Version
*#2222# H/W Version
*#8999*8376263# All Versions Together
*#8999*8378# Test Menu
*#4777*8665# GPSR Tool
*#8999*523# LCD Brightness
*#8999*377# Error LOG Menu
*#8999*327# EEP Menu
*#8999*667# Debug Mode
*#92782# PhoneModel (Wap)
#*5737425# JAVA Mode
*#2255# Call List
*#232337# Bluetooth MAC Adress
*#5282837# Java Version
Type in *#0000# on a Samsung A300 to reset the language
Master reset(unlock) #*7337# (for the new samsungs E700 x600 but not E710)
Samsung E700 type *#2255# to show secret call log (not tested)
Samsung A300, A800 phone unlock enter this *2767*637#
Samsung V200, S100, S300 phone unlock : *2767*782257378#
Dec 01, 2013 | Cell Phones
After installing new batteries I have lost my time and date on the window display
The date and time is supplied with the caller ID information from your phone service provider. When you get a call, the date and time will be set. (If you don't have caller ID, there's no way to set the date and time otherwise. I've always wondered who came up with such a silly design.)
Jan 30, 2011 | GE 29385GE1 Corded Phone
Emerson EM2515
The phone actually has a "OPTIONS MENU" where you can set the date. When the display is showing time and date, press the "DIAL" button first and then while still holding down the "DIAL" button, press the "DEL" button the "Options Menu" will appear after about three seconds of holding down both buttons. Use the "REVIEW" arrow buttons to scroll through the menu and the "DIAL" button to select the options.
Jun 09, 2008 | Emerson Corded Phone
Round button in middle quits working.
Sounds like you may not be selecting the right menu buttom. The soft keys are right below the screen. these three buttons function change depending on which screen you are viewing. I have copied the instructions from the manual below. You must select phonebook to view the phone book using the round button. You must select volume to change the volume with the round button.
The Standby Screen
When the phone is in standby, the handset display shows the following items:
Handset
Ringer off icon (when the ringer is off)/ day of the week and time / battery iconHandset ID and BannerNumber of new Caller ID calls received (If there are no new Caller ID messages, the Handset ID appears here.) SUN 12:00A Handset #1 New CID: 5REDIALMENU
Using the Four-way Function Key
Your handset has a four-way function key that allows you to move the cursor (or highlighted area) on the display and access the most commonly used features at the touch of a button. By moving this key to the left, you open the Phonebook. Move the key to the right to access Caller ID information. To use this four-way key, place your thumb over the key on the station and move to the four positions to get the feel of how it moves and operates.
Using the Handset Menu
To open the menu, press the MENU soft key. Highlight the option you want by pressing the four-way function key. This will move the cursor; the option currently highlighted appears in reversed out text. Select the highlighted option by pressing the OK soft key. To exit the menu and return to standby, press [].
If you do not press a key within 30 seconds, the phone will time out and exit the menu. When setting Date and Time, the time-out period is extended to two minutes.
Note: For GLOBAL SETUP and DEREGISTRATION menu options, make sure the line is not in use and the handsets are within range of the base. 123abcdefView the phonebook Four-way Function KeyUpView the Caller IDDown123abcdefView •
Jan 31, 2008 | Uniden TRU9480 Cordless Telephone
No lcd display-cannot set up phone
try replacing the batteries in the base
Jan 02, 2008 | Innovage 1502084 Corded Phone
Samsung g600 - receiving a call
Click Menu > # Settings
1 Phone settings
On this you can change the setting on what to be displayed when you receive a call.
Phone settings
→ Show caller
information
Set the phone to display or
block caller information on
all missed calls and
incoming messages
Let me know if you need more info
Jan 01, 2008 | Nokia 1600 Cellular Phone
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Caller id
This is a feature from your phone company you may have to pay extra for. Caller ID information is normally transmitted just after the first ring. When you are using call waiting there is no ring.
Jun 19, 2007 | Uniden DCX640 Cordless Expansion Handset
RCA 25202RE3 Corded Phone Logo
184 people viewed this question
Top RCA Lands Phones Experts
Marvin
Marvin
Steve Allison
Steve Allison
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
