Question about Whirlpool GHW9100L Front Load Washer
Clothes washer problem
My washer duet is not pumping the water out and does make a very low grilling noise
  • 5,911 Answers
It sounds like you either have something caught in the drain pump reservoir, or the pump itself has failed. The following link explains how to access the drain pump to check it:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Helpful HINT: Using a wet/dry shop to drain the tub through the drain line is strongly recommended. Especially, if the wash tub is still full of water. Otherwise, you will have to mop up about 5 to 7 gallons of water from the drain pump.
Check the pump and drain lines for clogs and check the impeller (can be viewed with the strainer removed) for anything obstructing it from moving. If the pump is damaged and cannot pump at the correct volume, you will experience errors and/or the tub will not drain. If this occurs, the pump has to be replaced. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 27, 2010
Won't drain. Won't spin.
Sounds like there's a blockage in the drain hose, or the pump. There could be a coin jamming the pump impeller. If the clothes are wet it's got to be a drainage problem...Good luck....Nomess
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Rumbling noise during draining
i know with my fridgeadair it was the pump going out of mine , it would take me 3 spins to get the clothes wrung out enough to put in the dryer.
Dec 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get...
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
May 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
