Question about Canon XL1S Mini DV Digital Camcorder
TApe recording I'll be recording then i will be in stop mode the when i get ready to record again, i get a "please eject Tape" in my view finder...What do i need to do
  • 48 Answers
What is happening is the end of tape senor is bad. its about a 3.00 part and 20.00 repair fee.
Posted on Sep 25, 2008
    Sergeant:
    Champion:
  • 317 Answers
Try using a different tape, some tapes are what you call "wet" meaning they have a lubricant inside them and some cameras don't like them. Try to use Maxell Brand tapes I have used the for over 4 years and never had a problem
Posted on Jun 30, 2008
SOURCE:
In playback my camcorder stops and 31:11 flashes. Any ideas?
This most likely means the taps is jammed.
You can try and get the tape to eject. To do this, remove your battery from the back of the camera. Also if your camera has another small battery under the LCD (the size if a nickel) remove it too. Wait 2 minutes. Then, plug the camera in with the power cord. Try changing the camera from playback to record mode. The tape should eject at this point. If this doesn't work, try it again but this time start in record mode and change to playback after plugging it in.
I hope this helps.
Mar 31, 2011 | Cameras
When I try to tape a program to the vcr, the tape ejects when I press record. I unplugged it as suggested in the manual and tried again. The dvd works fine.
Check the record switch in the video recorder. The thing that pushes on the tab on the video tape! If bent or broken, your VCR will assume that the blank tape has no tab and thus eject it, as though it was a protected tape!
Mar 04, 2010 | Televison & Video
Vhs tape ejects when pressing record
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Feb 05, 2010 | LG Televison & Video
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
VCR won't take tape
Is it ejecting the tape when you set up for timed record, or any record mode for that matter? If so, check for the presence of the record lockout tab in the tape. If tab is there, machine should accept it. If machine ejects tape with the tab present, then the sensor which detects tab present or absent is probably afoul. this sensor is often a small switch. This tab, by the way, is on the backside of the tape, on the left, looking at the tape from the back.
Apr 14, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Mar 11, 2007 | Sony SLV-ED85 VCR
Canon XL1S Mini DV Digital Camcorder Logo
87 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
