Question about Hitachi Drills
I brought an old ''Hitachi DH 25 Y sds hammer drill'' but unfortuntely the SDS bit won't fit in it, it is 2 small, and the other sds type is 2 big. is there a Hatchi standard SDS Bit?
4 Suggested Answers
  • 21 Answers
SOURCE: strange wurring sound and slight vibration at full
On most sds drills the movement of the beat piece inside the piston cause then to vibrate, even at slow speed, this is normal, the most speed the louder the noise and vibration., note: is not a grinding noise, it should be a smooth nocking constant sound, as so the vibration.
Posted on Sep 26, 2009
  • 52 Answers
SOURCE: How to replace the hammer and striker
Sorry I couldn't be of more help. I've looked at about every DV 20 version parts list and cannot find a part 16 that would create any difficulty in removing. All are either gears, pins, or the plate that goes under the switch. from the way you are describing it it sounds like the only possibility would be the Model DV 20VB which has a spindle which has to be unscrewed from the drill chuck it is held in by a retaining clip that you would need retaining ring pliers to remove.
Posted on Feb 11, 2010
  • 304 Answers
SOURCE: how sds drill differ from ordinary rotatary drill .what are main basic feature of sds hammer drill
The difference is the working action. SDS drills use a corrugated cams running against each other.
Posted on May 30, 2012
What type of modern SDS drill bit fits a Hilti TE 72?
sds is a standard adopted by all rotary hammer drill manufacturers
It is the design of the slots and grooves in the end of the drill where it goes into the machine
it allows for many drill manufacturers to get their drills to fit any rotary hammer drill
early ramset drills used a special drill but they found that it was better to use the standard as well
Sep 04, 2017 | Hilti Drills
How sds drill differ from ordinary rotatary drill .what are main basic feature of sds hammer drill
May 30, 2012 | Drills
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
'Whats the difference between a te c3x bit and a sds bit'
The difference is the type of shaft on the bit so that it matches to the chuck type of the drill...They are NOT interchangeable!!!!
You need to know which type of check your drill has and order accorndingly...
heatman101
Aug 25, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
How do I fit drill in this machine please? DEWALT D25113K D25113 3 MODE SDS
Youcan only use standard drill bits with the use of a chuck attachment with the SDS type bayonet. These hammer drills use an SDS type drill bit which just pushes into the fitted chuck and are released by pulling back on the lock mechanism on the chuck.
Jan 19, 2010 | Dewalt D25213k D-handle Tri-mode Sds+...
I own a hd50spk hitachi...what drill bits are universal across the brands?
there are 2 main types of hammer drill bits, standard and SDS.
standard bits go in a regular style chuck hammer drill
SDS bits have 2 grooves and 2 elongated holes on the shaft which snap into the chuck
I'm not sure which type you have, but to answer, the 2 types are universal within their types
Jan 01, 2010 | Drills
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
www.toolpartsdirect.com
Sep 12, 2009 | Skil Drills
I need to know what carbide Masonry drill bits are available for the Hilti TE-6s and where I can buy them
Any SDS Plus or SDS drill bit will fit. Available at Home Depot, SEARS.
May 13, 2009 | Drills
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drills Logo
69 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
