Question about Kenmore 22422 Top Load Washer
Kenmore wascher machine
Remove top cover
    Novelist:
  • 184 Answers
ARE YOU WANTING TO REMOVE THE TOP COVER?
IF THE WASHER IS LESS THAN 25 YEARS OLD, THE TOP DOESN'T COME OFF BY ITSELF. IT IS ATTACHED TO THE CABINET WITH SCREWS FROM UNDERNEATH.
THERE ARE EITHER TWO SCREWS IN THE LOWER FRONT CORNER OF THE CONSOLE OR IN THE REAR CORNERS OF THE CONSOLE. REMOVE THOSE TWO SCREWS AND SLIDE THE CONOLE FORWARD AND PIVOT UP AND BACK OUT OF THE WAY. THERE ARE TWO CLIPS THAT HOLD THE CABINET TO THE BASE. REMOVE THE TWO CLIPS BY INSERTING A FLAT BLADE SCREWDRIVER IN THE FRONT HOLE THAT THE CLIP GOES INTO. PRY BACKWARD AND UP ON THE END OF THE CLIP TO RELEASE IT FROM THE CABINET. UNHOOK THE PLUG IN THE BACK THAT GOES TO THE LID SWITCH AND TIP THE ENTIRE CABINET TOWARD YOU AND LIFT OFF OF THE BASE. THIS WILL GAIN ACCESS TO THE MAJOR COMPONENTS.
Posted on Apr 10, 2008
I have a kenmore ultra care fabric series 80 and need to replace top cover on drum. How do I do this?
the top cover can be removed after removing the cabinet, the top snaps or clips on all alround the tub every 10 or so inches, u just have to unsnap it little by little
Mar 01, 2015 | Kenmore Washing Machines
80 series kenmore how do i remove the cover to change the lid switch?
The cover is not held down by anything but spring clips, take a putty knife and gently pry it up around the perimeter of the top cover lifting as you go..
Dec 23, 2011 | Kenmore Washing Machines
My kenmore 70 series washer will not spin or agitate
if you can hear the motor running,then its the direct drive coupler between the motor and transmission that the teeth are broken off and cannot mesh, you need to remove front panel to check,but,if no motor noise,then its your lid safety switch under the top cover,you need to remove front and top cover to check
Apr 11, 2011 | Kenmore 22422 Top Load Washer
Removing the top of a Kenmore Elite Oasis Washer to replace hose
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 17, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Removal of back panel on kenmore two speede washer
It does not come off.
Use the video attached to access the inside of the washer.
Apr 24, 2009 | Washing Machines
I can`t get the face cover off to oil it
on some of the kenmores there are 2 screws under the carring handle on the top of the machine you have to remove these. then lay the machine back and remove the screws on the bottom.the case should come of. if not there might be screws on the inside of the bottom plate.
Mar 09, 2009 | Kenmore 15516 Mechanical Sewing Machine
Dog Agit replacement on a Kenmore washing machine?
Take the top cap off the agitator.
Remove the plastic cover inside.(use pliers to pull it off).
Remove the bolt.
Pull the top half of the agitator off.
Replace the dogs.
Re-install the agitator.
Mar 08, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 22422 Top Load Washer Logo
91 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
