Question about Dishwashers
I need a schematic for Sears Kenmore Elite Dishwasher Model #665.13753K602
5 Suggested Answers
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
rylee_smith
  • 8619 Answers
SOURCE: kenmore 665 dishwasher will not drain
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 08, 2009
SOURCE: kenmore elite dishwasher 665 water won't drain
Mine's doing the same thing, would love to know if you found a solution
Posted on Jan 22, 2010
SOURCE: Kenmore Elite dishwasher model 665 touchpad buttons falling off
WE HAVE THE SAME PROBLEM. DID YOU FIND A FIX FOR YOURS?
Posted on Mar 27, 2010
Trying to troubleshoot the circulation motor before I have to dismantle the dishwasher. It is built in and would be a MAJOR project to remove.
Go to Sears, parts, and many times they have the schematics there to pull up and print. This is one of the reasons I keep buying a portable...fixing is a pain when permanent!
Mar 05, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a 3022 13929991 Ken Elite Dishwasher - I need to know where i can pull up a mannual got this at Sears Outlet Control lock is on and i can't get it off thanks for your help
Normally you should press the child lock for about 6 secs to turn it off. But if there is a fault in dishwasher then child lock light will be on or flashing.
This means some diagnostics is required to find the cause of the fault.
However, I don't think you have provided the correct model number of your kenmore elite dishwasher.
Normally it should be 665.xxxx Please check the model number carefully and post a comment.
Nov 26, 2010 | Kenmore Dishwashers
Reset sequence for Sears Kenmore Elite 630.1630?
Unplug for 40 minutes to reset this unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Need schematic for kenmore lid switch top loading washing machine door .
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Jan 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite: Model 66576962K601.
I had exact same issue. I've called Sears Maintenance. They had to change 2 pieces in UI: Timer KUDS02SRB10 and CONSOLE Assy. Cost 360$ pieces  130$ Job Charge 60$ taxes.
Now It works perfectly, but I bought 1100$ 3 years ago... Really expensive to keep it running.
Nov 29, 2009 | Kenmore Dishwashers
Dishwashers Logo
270 people viewed this question
Top Dishwashers Experts
