When I turn on the tv, there is no picture or sound (the ssreen display is just a series of lines). This lasts for about 5 minutes, then the picture and sound is fine. It remains fine for as long as the tv is running. After I turn it off for a while, and turn it back on, the same problem occurs.
  • 8,617 Answers
Sounds like a weak capacitor. Whats the model number? I should be able to give you some input. Is this by any chance a mitsubishi ?
Posted on Apr 07, 2008
How to fix a led tv that has vertical lines around 5 minutes after turning it on then disappears when the tv has warmed up?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 28, 2016 | Samsung Televison & Video
TV turns itself off after about 5 minutes (green light remains on). I can turn off the TV and turn it back on immediately, however, the TV turns itself back off after a few minutes. It started turning off...
Check and make sure your fans are working and there is sufficiant cooling to the back of the set. Sounds like it is overheating and going into protection mode.
May 04, 2011 | Mitsubishi WS-65513 65" Rear Projection...
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
My polaroid has sound and picture problems
This is a well-known problem with many Polaroid FP displays. Eventually, the picture will simply go black, rendering the TV useless. The solution is a new control board, ~$400.
Feb 27, 2009 | Polaroid FLM-4201 42 in. LCD Television
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Picture goes dead after 5-10 minutes
You may have a loose solder joint causing this problem. If you can take it apart, you mihgt try spraying circuit cooler in various parts of the circuit but NOT in the high voltage or horizontal circuits.YOU MAY CAUSE AN ARC OR A COMPONENT TO SHORT SINCE THE SET HAS TO BE IN OPERATION WHEN YOU SPRAY. If you hit the bad connection the picture will come back on. When the picture zaps to the middle of the screen, is there just a bright line? If so, then you have a loose connection or a temperature problem in the vertical circuit. Stargazer
Mar 03, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
