I put a Hitach DVD-ROM/CD-RW drive into my computer. This was to replace a a DVD-ROM drive. Windows XP seems to have found a driver for it without my intervention (unfortunately I have various system messages turned off (by accident)). My replacement drive played part of a video on a DVD successfully. Then I ran Optinfo to get information on the disk in the drive. I ended looking at the video and removed the disk. Since then, the DVD drive insists on pushing the DVD shelf out. Even if I put in a DVD and try to play it, as I did successfully before, I cannot do that now. What should I do?
    Brigadier General:
  • 10,406 Answers
Restart your computer.
When you see "Press DEL to enter SETUP",
press the 'DEL' key.
Stay in 'SETUP' mode.
Now, insert a disk into the tray, and close the tray.
If it stays closed, then your DVD-drive is working OK.
If it re-opens the tray, you have a hardware problem with the DVD drive. If your drive is less than one year old, it's probably still under "warranty". Exercise the warranty, and get it replaced.
Posted on May 27, 2010
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Drivers not found for my dvd-rom driver and cd-rw
your windows seems to be corrupt. check your hard disk for bad sectors.
Jun 13, 2009 | Microsoft Windows XP Professional
Won't recognize blank dvd
Chek wtat is written on front panel
If it DVD-RW it can record only DVD-R blank, if it + so only +R
or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
Also chek the speed for you DVD and disk you using.
If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
Good Luck
Jan 10, 2009 | Microsoft Windows XP Professional With...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have a DVD-Rom / CD-RW but no drivers to put in my computer?
can you explain further please,
has this drive been fitted yet?
what windows are you using?
windows normally picks dvd/cd rom without having to install drivers
Aug 11, 2008 | AOpen Computers & Internet
Lg dvd rom driver/combo drive
Dirty or out of alignment drive...accordianman
Feb 28, 2008 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Windows XP Pro - LG GCC-4243N combo drive not seeing data on disks
if you have lance cleaner then use it but shyore it one famouse brand otherwise it should damage yor cd om's lance if you found nothing then pls go to your hardware vendor
Jan 12, 2008 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
Memorex cd-rw/dvd-rom wont install
FOrget the cd in the box.
http://memorex.com/html/download_software.php?sid=15
Download the latest driver for the product, and matching your computer and operating system.
Oct 22, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
k24674
jasbo
jasbo
