I am newly in charge of an exchange server. For the last three mornings I have to come in to find the connection gone. A quick machine restart fixes this but is obviously not good for my mental health especially when corporate types are bearing down on top of me!
  • 13,433 Answers
What operateing system? if its windows try
start -> run -> cmd -> ipconfig /release
-> ipconfig /renew
Posted on Apr 07, 2008
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Tip
How to Setup Microsoft Exchange Server
<p>Microsoft Exchange Server 2003 released on September 28, 2003. One of the new features in Exchange Server 2003 is enhanced disaster recovery which allows administrators to bring the server online more quickly. This is done by allowing the server to send and receive mail while the message stores are being recovered from backup. Now newly released version of Exchange server is Exchange 2010 after 2007 version. Exchange server 2010 officially released on 9th November 2009. But here I will discuss about Microsoft Exchange server 2003. In a workstation most of users are use Microsoft Exchange server as mail server.<br /> <p><span><span><b>Requirement of Exchange Server 2003:</b></span></span> <span> </span>Required OS for Exchange Server2003 is Microsoft Server 2oo3. There this Server should be a domain controller. For Exchange 2003 need some protocol like <br /> <p> <br /> <p><span><span><b><span> </span><span> </span></b></span></span>1&gt; asp.net<br /> <p><span> </span><span> </span>2&gt; SMTP<br /> <p><span> </span>3&gt;NMTP<br /> <p><span> </span><span> </span>4&gt;W.W.W<br /> <p> <br> <p>IIS should be install in server . In hardware system should have minimum 256MB of memory<br> <p><span><span><b>Installation of Exchange Server 2003: </b></SPAN></SPAN>There have three steps to install Microsoft Exchange Server 2003.<br> <p><span><span>1&gt;<span> </SPAN></SPAN></SPAN>Preparation of forest<br> <p><span><span>2&gt;<span> </SPAN></SPAN></SPAN>Preparation<span> </SPAN>of domain<br> <p><span><span>3&gt;<span> </SPAN></SPAN></SPAN>Installation<span> </SPAN>of Exchange Server<br> <p>To install Exchange Server you have to install the required protocol first. I have install the windows component such as IIS, ASP.NET, NNTP, W.W.W. from control panel with OS CD. Then I insert the Exchange Server Disk in CD rom drive and start the preparation of forest. I open the disk and run the forest prep from Exchange 2003 deployment tools. It will take several times to complete. After completing the forest prep I have run the Domain prep with the same procedure. The Domain prep will take also lots of time to complete. Then I have installed the exchange server by creating a new exchange organization. The total process also possible to complete from Run with command. The total job takes a huge time almost one hour or more. After installing Exchange Server I have configured it as per direction of the company. I have add users, groups, I create new administrative group. Following this process there I have done the whole job successfully. <br> <p><span></SPAN>
on Mar 21, 2011 | Computers & Internet
How come my mail icon says cannot get mail
This is just a bug by Apple and has several quick fixes:
Move all items from inbox to a different folder. The most commonly successful fix for this issue is to move all items from the inbox into a temporary folder created on the server. It appears that problematic messages in the inbox can cause the error message.
Upgrade Exchange Server.You may need to apply a service pack to the Exchange server to which your iPhone is connecting. Some users have reported that they need to install Exchange Server 2003 Service Pack 2 to eliminate this error.
Jun 20, 2014 | Apple iPhone 5c
How come mail icon on phone says cannot get mail
Move all items from inbox to a different folder.The most commonly successful fix for this issue is to move all items from the inbox into a temporary folder created on the server. It appears that problematic messages in the inbox can cause the error message.
What you like any Best Novell Groupwise to Exchange tool?
A third party tool to convert GroupWise to Exchange server quickly in single click. Software support migration of different mailboxes to Exchange server which converts it into single PST file. Software provide two option to convert/migrate single or multiple mailboxes.
Download:- Stellar Phoenix GroupWise To Exchange
May 15, 2014 | Microsoft Database Software A5K-02817 SQL...
I have an exchange server that is connected to an ISA server. It stopped sending messages externally but can send and receive mails locally. I noticed that the ISA server in the IIS manager has Receiver...
Now when somebody reports that he or she is not getting any "outside"
emails, I go to Exchange System Manager -> Servers -> <server> ->Protocols ->
SMTP -> Default SMTP Virtual Server - > Current Sessions and I see a bunch of
.br, .it, .ar, OHIOIJHOJOJI, etc, user names with connected times 98353566,
43543543, 3453453 seconds, or in another words with endless connection times.
I understand, that once the exchange reaches the number of connections of
50, it stops accepting new connections, stops receiving emails and here is my
qustions:
1. Why the "Terminate All" command doesn't remedy the problem with email flow?
As the second option, I try to restart SMTP service, but it freezes in a
stopping mode leaving me with only one option to restart entire server. (BTW,
I've also noticed that it feezes after I update IMF filter and I need to
restart the server)
2. what are those connections and how to protect Exchange from them?
Dec 16, 2008 | Microsoft Windows XP Professional With...
New to exchange server 2003
Hello there!
First things First!
1) you always going to have problems with exchange servers, or migrations. ** systems are not perfects**
2) You can migrate the emails to the new server, but, if only are in the correct version of Exchange 2003.
3) if backup is damage or fail, you lost everything.
4) try to reinstall the Server, and all utilites, is better, I know takes more time, but is better because you created yourself.
I suggest you to install from scratch!
Good luck
Feb 24, 2008 | Computers & Internet
New to Exchange Server 2003
U mail is noted friend.. U all files and foeld is xchange the new Windows Server 2003, than no problem..
Feb 24, 2008 | Microsoft Windows Server Standard 2003 for...
Exchange server 5.5
Firstly, Retention periods may be set up in the exchange so that mail is kept within Exchange for a period of time even thought the users may have deleted it. Check out http://support.microsoft.com/kb/246283 to change the standard retention policy to suit.
Also using a tool to defragment the Exchange Database may be useful - Try PerfectDisk for Exchange. But remove as much other stuff as possible first as it needs space to work.
A couple of things... Exchange 5.5 has been replaced three times now and support ceased from Microsoft on 31st December 2003. NT Server support ceased a year later and is about to be replaced for the third time as well. I'd REALLY look at getting more up to date software on suitable hardware.
When deleting emails, remember any legal requirements you may have for retaining / archiving emails.
James
www.small-biz.it
Feb 11, 2008 | Microsoft Outlook 2001 (outlook2001) for...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
