Question about Viking E-30-PT Stainless Steel - - Phone
I have a new viking E-30-EWP that I just installed. I can not get the phone to answer so I can program it. I have the #2 dip switch turned on.
    President:
  • Viking Master
  • 860 Answers
Thats kinda odd, viking products rarely have out of box failures . I would have to verify that the number that your calling to connect to the door box is correct. Other then that I'd have to say that you've got a bad one.
Posted on May 27, 2010
Need manual for harbor breeze fan model # LP8063
The remote went bad, this is very common. These are great fans with poor design and cheap remotes. Go to Lowe's buy the new kit ( model: RCE-103LW) $30 bat included. Put battery in and turn off light switch. Have a bic pen ready with the battery cover off. Turn on light switch and press "learn" red button with the pen . You will have to hold it down for about 5 secs. The fan will the turn on medium if it took to learning the new remote. All buttons should now work normal. Return old remote to store for exchange they have a 1year return to to store warenty per the company rep. Anyother problems call 1 800 527 1292. They have good cust. Service.
Jul 21, 2012 | Dryers
I have wanted to install csc orion 16 but i could not. please what software should i need to install before i can install csc orin 16
I'm not familiar with that program. This particular forum is for sewing machines by Viking Husqvarna. Sorry, I can only answer what I am familiar with. You should take this to the computing forum.
Nov 16, 2011 | Husqvarna Viking 1
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
I've owned a a 2000 Plymouth Grand Voyager for a year now. I change my own oil in it. Twice now, when I'm done and checking the dip stick for the oil level, the stick is bone dry! The first time this...
The van must be on level ground while checking. after adding the correct amount of oil making sure to prime the oil filter before installing run the van for approx 30 seconds turn off and recheck after 1 min.
Aug 03, 2009 | 2000 Plymouth Grand Voyager
My Rheem Tankless Hot Water Heater is installed, but is it not attempting to start. The digital display keeps blinking 82, 0, 82 , 0 ...?
If this is a new board and Altidude chip with power on set dip switch 1 and 2 to on. Then press and hold adjust button until on board blinks fast then and you will see dashes on LCD display. Set dip switches 1 and 2 back to off. Turn on remote unit and you should see 100F. With any luck you are good to go.
May 02, 2009 | Rheem Tankless Hot Water Heater...
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
Viking E-30-PT Stainless Steel - - Phone Logo
139 people viewed this question
Top Viking Lands Phones Experts
David Burbee
David Burbee
Are you a Viking Lands Phone Expert? Answer questions, earn points and help others
