Question about Kenmore 72126 Air Conditioner
Noisy with water coming from front - Kenmore 72126 Air Conditioner
  • 901 Answers
Check whether the ac drain pipe is blocked.
Posted on May 27, 2010
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
Noisy Hot Water Gushing In Boiler
You may excess air in the lines
Nov 06, 2012 | Water Heaters
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Noisy engine, probably due to tension bearing adjustment?
They can be noisy, my rodeo sounds like a diesel. But, it might be something else, belt tensioners usually only tap, one time every rpm, valves might make more racket, rods sound like a snare drum under neath the car, check the oil, the sound should be coming from the front of the engine. Water pumps, alternators, ac comp, all can be noisy. Turn off the ac when listening. Watch out for the fan. A long screwdriver or a piece of wood with ear against the end will quickly find a noisy part.
Feb 10, 2010 | 2003 Honda CR-V
Have an SRD522VW F/F abt 12 years old now leaking water(?) from freezer side somewhere. still going but noisy
You might have a stopped up drain line, and when the evaperator goes into defrost the water is coming out the front instead of in the drain pan. the best way to check is to pour some water in the drain hole in the back of the freezer and see if it goes through or just pools up and runs out the front. I ususally check that before anything else.
Oct 16, 2009 | Amana Refrigerators
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Very noisy squeky fron suspension on jaguar xj8
You might need a lube job or you may need to see if noise is coming from another place such as your engine water pump, brakes, power steering. Look for leaks.
Sep 14, 2009 | 1998 Jaguar XJ8L
Whirlpool wfs1285aw noisy spin cycle
Hi..
If you washer is noisy,
  • Check that the water supply valves are turned on
  • Inspect the filter screen
  • Test for overheating
  • Inspect the water pump
  • Test the water inlet valve
  • Test the motor
General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Good luck !!!
Regards
PCmania
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Not spinning
I found my Classixx 1200 express with a flashing spin light, the water wasn't up in the drum, so I moved the selector to rinse, and pressed start, pump was noisy but worked, I could hear water going into the drain, thinking I'd got a blockage in thye pump, I drained machine using small hose and inspected the pump orifice at the front of the machine (towel handy to catch spillage.
No obvious blockage and the pump could be turned by hand, tried rinse again with water feed turned off, (otherwise it pumps for a while and then lets water in to rinse - which comes out the open pump housing!) I could see the pump impeller spinning but also sticking, its was also noisy.
Solution - new pump, according to my local spares shop, the pump is available as either motor & impeller (back half), or complete with black housing that the pipes fit to, to get the front cover off, and to remove the pump, you need a "star" screwdriver or key, and a pair of pliers to undo the hose clips - have a bowl ready to catch the water, and make sure the machine's unplugged before you start!
Jul 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Kenmore 72126 Air Conditioner Logo
32 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
