Question about Toyotomi TID-1800HP Air Conditioner
How do we operate it. should it blow hot air out the back
  • 15,935 Answers
CLICK HERE for the user manual.
You should duct the exhaust as noted on page 10 of the manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on May 26, 2010
I ran the air conditioner yesterday and everything was fine, when i got in this morning, it was cool so i turned into vent and moved the thermostat to red. This afternoon it was warm so moved it back to...
I'd probably check the blend door under the dash for proper operation. Sorry, I don't have any pictures. Also, if the blend door is vacuum operated, check the vacuum. I did check hvac wiring diagram, didn't show any actuators, so, I believe vacuum operated. I'd have to look at it, to diagnose further, sorry I don't have better info.
Make sure it is full of refrigerant and compressor clutch in engaging.
Jun 26, 2017 | 1997 Buick Skylark
Bmw defroster blows hot air/vents only blw cold air
These selections are run by Engine vacuum. sounds lie a diaphragm is NG to control the lower door
Jan 08, 2014 | BMW Cars & Trucks
How can i fix the heat to blow hot air in my 1996 ford econoline250 cargo van
so either the blower motor isn't blowing or its just blowing cold air-always start with fuses-then check for 12v at the blower motor-use a volt ohm meter- if you have 12v then the blower motor is bad-if there is no warm air blowing out-look for the water valve that lets the hot water into the heater core-its on the small hose going back to the heater core-make sure its operating-cheers Denny
Nov 30, 2013 | Ford E-250 Cars & Trucks
Heat blows cold air front and rear when sitting still or @ low mph.
Usually a sign of low coolant or a blockage in the circulation.
Feb 26, 2013 | 2003 Chrysler Town & Country
Heater not working
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | 2001 Ford Taurus
Blows hot air
If your machine is an air conditioner then the little hose needs to drain condensation to the outdoors. Most of the time there is a pump that the hose is attached to inside the unit. If the overflow switch is open the compressor contactor will not operate but the fan will.
Jun 19, 2010 | Maytag M6P09S2ACOM Air Conditioner
HEATING PROBLEMS
Need more information. The most important thing would be to watch the heater water valve move when someone turns the control from hot to cold, back and forth?
Heater valve controls tend to be operated by vacuum, and switched by a heater computer. Lots of possibilities. But first tell us what you see move when operated? Valve is usually in engine compartment, in the heater hose. Follow the hot one.
Jan 03, 2010 | 1999 GMC Sierra
Rear airconditioner blowing hot air
CHECK TO SEE IF ANY OF THE CABLES HAVE BECOME DETTACHED FROM THE HEATER OPERATION
Jun 13, 2009 | 2000 Ford Econoline
Ac blowing hot air instead of cold
Check for the following problems
(1) Check if compressor is geting power
(2) Check if system have Refrigerant in it
(3) Check if pressure switches are operational
(4) Check Thermostrat setting.
(5) Check for dirty or block condenser or evaporator
Send feed back if you solve problem
Mar 26, 2008 | Hunter 30124 Air Conditioner
Toyotomi TID-1800HP Air Conditioner Logo
83 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
